parking brake pedal - Team Camaro Tech
post #1 of 8 (permalink) Old Apr 21st, 19, 05:13 PM Thread Starter
Probationer
parking brake pedal
I've got an issue with a parking brake pedal that doesn't return all the way to the released position so the parking brake idiot light stays on in my '69 Z28. Purchased a parking brake pedal return spring but can't seem to figure out where to hook it up. HELP anyone...
Rick Gibala is offline
post #2 of 8 (permalink) Old Apr 22nd, 19, 09:00 AM
keith
X-77 keith's Avatar
This the spring you are talking about?
ID:	226663   Click image for larger version
X-77 keith
X-77 keith is offline
post #3 of 8 (permalink) Old Apr 22nd, 19, 05:53 PM Thread Starter
Probationer
Re: parking brake pedal
thanks for the reply Kieth, but the spring in your pic is to return the parking brake handle to the start position (my car has that spring and works properly). I'm talking about the foot pedal not returning all the way up so that the idiot light goes out. Don't know if there's a spring missing under the dash or somewhere under the car?
post #4 of 8 (permalink) Old Apr 22nd, 19, 05:57 PM
keith
X-77 keith's Avatar
Check your adjustment for the parking brake cable under the car. If it is loose, you will not have tension on the pedal. This could make a worn pedal droop down causing the switch to not make contact.
X-77 keith
post #5 of 8 (permalink) Old Apr 22nd, 19, 08:15 PM
There's good pics in this thread. In post #6 you'll see the cable spring forward of the yellow arrow
compressed against the frame rail as it passes through the rail. You may just need to simply adjust
the cable(s) (yellow arrow).
https://www.camaros.net/forums/16-br...ake-cable.html
my 67' build thread:
allanjs is offline
post #6 of 8 (permalink) Old Apr 24th, 19, 05:46 PM Thread Starter
Probationer
Thanks, Kieth !!
I'll try making the adjustments you suggested ,BTW great pics, let you know how it works out
post #7 of 8 (permalink) Old Apr 25th, 19, 07:38 AM
Good suggestions given AFTER you've brake spooned the rear brakes.
Meaning manually adjust the rear brakes with a brake spoon and have the shoes barely drag against the drum(s), as in hearing them drag.
Then adjust emergency pedal for full engagement after 8 clicks (industry standard)
Then adjust switch flapper on pedal.
Doing a good job is like peeing in your dark pants … you get a warm feeling, but nobody notices
post #8 of 8 (permalink) Old Apr 25th, 19, 10:25 AM
Everett is correct. Be sure the rear brakes are adjusted prior to adjusting the parking
brake cable. I see Brain added the pic I referenced from the thread I linked to in my
earlier post.
allanjs is offline
Wire removal method for parking brake switch Bigbaddad Electrical & Wiring 3 Mar 9th, 19 07:42 PM
Parking Brake switch release? SoCal805 Brakes, Suspension & Steering 16 Feb 9th, 19 02:20 PM
front parking brake cable question 3d cad Brakes, Suspension & Steering 1 Nov 11th, 18 07:21 AM
Brake booster and pedal problem 69firebird461 Brakes, Suspension & Steering 9 Aug 31st, 18 01:05 PM
rear brake lines zboss86 Brakes, Suspension & Steering 11 May 6th, 18 12:40 PM
