Interesting tidbit about Right Stuff rear disc conversion. - Team Camaro Tech
 1Likes
  • 1 Post By Fred Mertz
post #1 of 1 (permalink) Old Apr 21st, 19, 08:50 PM Thread Starter
While working thru a problem I've had for years, I discovered why I couldn't get the parking brake to work correctly. The return spring at the e-brake lever on the caliper is too long. What was happening, was coil-bid not letting the pedal go down anymore than half way. I cut off about an inch and a 1/4 off the spring on the left and right caliper. Now the travel on the pedal doesn't stop half way down. And the e-brake now works like it should.
If you are having a similar problem this little trick just might help you out.
Legacy 69 likes this.
Known to run with scissors....
__________
1969 Camaro Z/28 "clone", GMPP ZZ383, Autogear M22W, Moser 12bolt w/TruTrac 3:73.
Fred Mertz is offline
Rear Disc Conversion Help Please.... tmoney Brakes, Suspension & Steering 9 Mar 16th, 19 05:57 PM
Rear disc brake conversion: TRS (Caddy), SSBC (T-Bird), Wilwood or ? stantaur Brakes, Suspension & Steering 8 Dec 2nd, 18 11:35 AM
Right Stuff Manual Disc conversion proportioning valve mount Kilr67 Brakes, Suspension & Steering 1 Nov 18th, 18 10:34 AM
Rear Disc Brake Conversion The Camaro Guy Brakes, Suspension & Steering 4 Jul 27th, 18 08:48 PM
Rear Disc brake Conversion The Camaro Guy Brakes, Suspension & Steering 1 Feb 11th, 18 06:51 PM
