Brake Pedal Adjustment - Team Camaro Tech
post #1 of 2 (permalink) Old Apr 22nd, 19, 03:26 PM Thread Starter
Charlie
I have a 69 Camaro SS with PDB on all four corners and noticed that the brake pedal does not fully release/disengage, resulting in brake drag. It will release when I put my foot under the brake pedal and pull up, although looking to fix this.
Would greatly appreciate if you guys could provide a step by step on how best to correct this.
Thank you all......
Charlie
Edmonds, WA
1969 Camaro SS Vert LS1 T56
camaromaniac is offline
post #2 of 2 (permalink) Old Apr 22nd, 19, 05:35 PM
Steven
stamatisg1977's Avatar
You may have something binding up on the brake lever assembly. I would check the plastic bushings. Second i would check booster rod to see if its bent.
Third i would install a return spring
69 Frost Green Camaro
LS3 with TSP stage 3 cam
Tremec TKO 600
Ridetech rear 4-Link
Follow my journey here:
stamatisg1977 is offline
parking brake pedal Rick Gibala Brakes, Suspension & Steering 7 Apr 25th, 19 10:25 AM
Brake Pedal linkage 57s67RS/SS Brakes, Suspension & Steering 2 Apr 20th, 19 06:57 PM
Brake booster and pedal problem 69firebird461 Brakes, Suspension & Steering 9 Aug 31st, 18 01:05 PM
rear brake lines zboss86 Brakes, Suspension & Steering 11 May 6th, 18 12:40 PM
