cant remove hooks from spring compressor - Team Camaro Tech
 5Likes
post #1 of 17 (permalink) Old Apr 27th, 19, 06:11 PM Thread Starter
Joe
cant remove hooks from installed coil spring
I am installing ridetech dual-rate springs...install was no problem. I am using the spring compressor below. I absolutely cannot get the hooks out of the installed spring. I have tried every which way to rotate and turn but its not coming out. I cant slip it through nor straighten it out. Also, the hooks cannot be removed (which I was able to do when I rented the spring compressor with 2 sets of hooks when I removed the old springs) Any ideas?
The second picture is how it is now, because I started to take it back off and even that is presenting challenges...there is less spring length to compress because of the tight coils on the bottom and its a shorter than stock spring.
Sent from my SM-G930T using Tapatalk
1967 Camaro RS 350, muncie
1970 Chevelle 454, 200 4r
jcor12 is offline
post #2 of 17 (permalink) Old Apr 27th, 19, 07:26 PM
Re: cant remove hooks from spring compressor
Both sides of the forked plate should be on the same coil. Not 1 coil apart as you have it.
Also you have the plate and hooks too close to each other. You need space between the
plate and fork base. The way I see it you're going to have to remove the spring with the
compressor attached and reset the compressor properly. Also be sure the threaded rod
isn't hitting the top of the spring tower. If the spring is short enough you may not need
the compressor.
my 67' build thread:
allanjs is offline
post #3 of 17 (permalink) Old Apr 27th, 19, 07:44 PM Thread Starter
Joe
the compressor.
Al,
Thanks...I agree that the plate needs to be on the same coil...but I couldn't get the plate in far enough to center it because the coil below is too tight so once the plate slid up I could then center the plate. I cant get the hooks any higher because they bind. I was trying to get just a little compression to take it back off. The spring hasn't released yet and I dont want to use the fork tool because I will ruin the new balljoint boot. Dont want to beat on the new parts installed. I may have to grind off the hooks and ruin the spring compressor. I can get the hooks to freely spin around and drop down to the lower control...just cant snake it out.
jcor12 is offline
post #4 of 17 (permalink) Old Apr 27th, 19, 08:01 PM
You don't need to use a ball joint separator forked tool. Just back the nut off so
you've still got about a full nut worth off threads engaged. Position a floor jack
under the spring pocket leaving a slight amount of clearance. Then hit the ball
joint knuckle with a BFH. It'll pop loose.
allanjs is offline
post #5 of 17 (permalink) Old Apr 27th, 19, 08:13 PM
If you can get the forked compressor plate and the threaded rod out then do as I just
described. After poping the ball joint loose remove the nut and slowly lower the control
arm but not fully releasing the spring. This will expand the spring and should give enough
room to remove the hooks. You may have to pry the coils open some but I'd bet you get
the hooks out. This is all assuming the motor is in the car for weight allowing you control
of the control arm without things flying apart.
allanjs is offline
post #6 of 17 (permalink) Old Apr 27th, 19, 08:19 PM Thread Starter
Joe
[quote=allanjs;1783135457]You don't need to use a ball joint separator forked tool. Just back the nut off so
joint knuckle with a BFH. It'll pop thread
jcor12 is offline
post #7 of 17 (permalink) Old Apr 27th, 19, 08:21 PM Thread Starter
Joe
I have the subframe out of the car, so no weight on it.
jcor12 is offline
post #8 of 17 (permalink) Old Apr 27th, 19, 08:38 PM
Hit the spindle knuckle where the ball joint taper fits. Not the ball joint threads.
With the sub out your going to have to use a different strategy so thing don't fly apart.
I've done it with a chain and jack. I don't have the time right now to explain so work safely.
jcor12 likes this.
allanjs is offline
post #9 of 17 (permalink) Old Apr 28th, 19, 12:14 AM
David Pozzi
davidpozzi's Avatar
You donít need a spring compressor for aftermarket coils with sub in the car. With sub out of the car, or no engine, I use a long piece of allthread & use a piece of drilled steel bar stock large enough to cover the shock hole on the lower A arm. I think I used 1/2Ē allthread.
dhutton and jcor12 like this.
davidpozzi is offline
post #10 of 17 (permalink) Old Apr 28th, 19, 04:21 AM
kevin
my sub frame was not out of the car, but there was no front end or engine when I installed my springs.
I used a floor jack and sand bags. that is it
flat tire is offline
post #11 of 17 (permalink) Old Apr 28th, 19, 05:12 AM
A jack and chain is all you need like Al stated. I bought this efficient tool years ago: https://www.amazon.com/OTC-7045B-Fro.../dp/B000GTJ5I8. Worth it if you do this work often.
jcor12 likes this.
Call for restoration and custom paint scheduling:
Sauron67MM is offline
post #12 of 17 (permalink) Old Apr 28th, 19, 05:41 AM
Use David Pozziís method. Easiest and safest by far.
1959 El Camino project
1957 Buick Caballero project
dhutton is online now
post #13 of 17 (permalink) Old Apr 28th, 19, 05:57 AM
Vega$69's Avatar
The spring compressor you have will not work. You will never be able to remove the hooks after the spring is installed.
All thread or the tool Scott posted will work,
jcor12 likes this.
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #14 of 17 (permalink) Old Apr 28th, 19, 09:24 AM
Steve69SS396's Avatar
It looks like the style of compressor I've used on my car. If it is, it has bolts holding the hooks in place. Remove the bolts so the hooks can be pulled out separately.
Steve69SS396 is online now
post #15 of 17 (permalink) Old Apr 28th, 19, 09:28 AM Thread Starter
Joe
Originally Posted by davidpozzi View Post
You donít need a spring compressor for aftermarket coils with sub in the car. With sub out of the car, or no engine, I use a long piece of allthread & use a piece of drilled steel bar stock large enough to cover the shock hole on the lower A arm & through the frame shock hole. I think I used 1/2Ē allthread.
thanks Dave...would never have thought that the shortened spring would be "short enough" that a compressor may not be required...i have the spring back out. I'm moving on to replacing motor mounts today.
jcor12 is offline
proper orientation of coil spring compressor jcor12 Brakes, Suspension & Steering 12 Dec 15th, 18 09:05 PM
Leaf Spring Front Perch Question Domano 68 Brakes, Suspension & Steering 7 Dec 10th, 18 04:49 AM
A/C Compressor horrible Squeal daverichard Heating & Cooling 7 Sep 27th, 18 09:46 AM
Are jets my next step? 4Speed67CamaroRS Engine 19 Apr 10th, 18 10:37 AM
