Power steering pulley - Team Camaro Tech
post #1 of 3 (permalink) Old Apr 28th, 19, 09:00 PM Thread Starter
Apprentice
Bob
I would like to buy the pulley set below. Can I use the spacer and fan that is on the engine now with the new water pump pulley having tapered bolt holes? I would like to know if any one knows weather 1967 small block power steering pumps use a key way, or are they press on? I need to upgrade to a 3/2 pulley system to add my Vintage air, so if you have another suggestion I am all ears.
https://www.ebay.com/itm/Small-Block....c100167.m2940
bobmeyer1958 is offline
post #2 of 3 (permalink) Old Apr 29th, 19, 10:27 AM
keith
X-77 keith's Avatar
Should have a keyway. If it has a bolt on it it is a keyway pump. I think mid to late 69 changed to press on. My 69 was a keyway pump.
X-77 keith
X-77 keith is offline
post #3 of 3 (permalink) Old Apr 29th, 19, 10:46 AM
Re: Power steering pulley
My 67 pump pulley is keyed and retained with a nut. The pulley set you're looking
at appears to me it assumes use of electric fans. I wouldn't trust it with your stock
bolt on fan.
my 67' build thread:
allanjs is offline
Wheel not straight after power steering conversion Charles Martin Brakes, Suspension & Steering 8 Mar 28th, 19 07:05 PM
Power Steering conversion 1967 Charles Martin Brakes, Suspension & Steering 0 Feb 27th, 19 10:18 PM
1968 396/375 power steering pump pulley # 3873847DH BBCMUSCLE Restoration Corner 0 Sep 25th, 18 10:46 PM
69 Camaro power steering pulley cjparks56 Brakes, Suspension & Steering 4 Sep 2nd, 18 04:51 PM
Are jets my next step? 4Speed67CamaroRS Engine 19 Apr 10th, 18 10:37 AM
