Anti-Seize on Brake Fittings - Team Camaro Tech
 5Likes
  • 5 Post By davidpozzi
post #1 of 10 (permalink) Old Apr 29th, 19, 12:29 PM Thread Starter
Bobby
I would not suspect that Anti-Seize should be used on brake fittings? I only ask because for the life of me I can not loosen this fitting shown in the image.
My YouTube LS3 Engine Swap Page
My LS3 Engine Swap Thread
Sixty8Camaro is offline
post #2 of 10 (permalink) Old Apr 29th, 19, 01:29 PM
Robert
Re: Anti-Seize on Brake Fittings
Do you have a heat gun? I would try warming it up a little bit but not with a torch or open flame of any kind. I am sure you can get it off with a large vice grip or channel locks, but that is going to destroy the nut, so you will have to put a new end on and re-crimp the line. But the large connection on the end looks like it has some thread sealant of some sort.
AKXtreme
69 Camaro L48 SS350
M20 4spd
akxtreme is offline
post #3 of 10 (permalink) Old Apr 29th, 19, 01:42 PM
David Pozzi
davidpozzi's Avatar
Use a flare nut wrench, then put a pair of vise grip pliers over it to keep it from spreading
130fe, HawkX66, allanjs and 2 others like this.
davidpozzi is offline
post #4 of 10 (permalink) Old Apr 29th, 19, 03:27 PM Thread Starter
Bobby
Thanks guys for the replies but Iím pretty sure the fittings can not be removed with out cutting it. It is definitely cold welded in there.
Was hoping to learn if itís safe to use a little permatex anti-seize to preventing it from happening again?
post #5 of 10 (permalink) Old Apr 29th, 19, 06:49 PM
Careful with the heat due to O-rings/seals.
68 Camaro~LSx ~all motor
post #6 of 10 (permalink) Old May 1st, 19, 08:39 AM
R66
Ron
No problem with anti-seize on the threads of the line nut (fitting). The line is a flare fit and seals at the flare, not the threads of the nut.
R66 is offline
post #7 of 10 (permalink) Old May 1st, 19, 10:02 AM
For the ones that are seized and won't come out with a wrench, usually I cut the tubing and use a socket. If there's enough tubing you can sometimes get away with flaring the cut tube, cleaning up the fitting and you can reuse it.
As long as I've been working on cars I never thought about that one. I love it. Learn something new every day!
'69 SS396 X66 L34 08D M21 BS
460ci Gen VI 9.75:1 AED 950 carb
Semper Fi!
HawkX66 is offline
post #8 of 10 (permalink) Old May 2nd, 19, 07:05 AM
Ed
Yes, you can use anti-seize, but make sure you only apply it to the threads and no where else. To break it loose, I would put a flare nut wenech on it and the use a long piece of pipe over the wrench to give you some leverage.
ZEN357 is offline
post #9 of 10 (permalink) Old May 2nd, 19, 10:23 AM
Jon
most brake lines seize the nut to the line. you can use anti seize under the nut on the tube and on the threads with no ill effects.
I am a believer of anti seize on every bolt that doesn't get a sealer, a locking compound or a assembly lube.
saon is offline
post #10 of 10 (permalink) Old May 2nd, 19, 12:12 PM Thread Starter
Bobby
Thanks everyone's for replies.
I suspect the only consideration is not to glob it on, I don't think it would be good for it to mix in with the brake fluid within the line.
If it did it would probable act as an air bubble would?
1969 firebird convertible with photos tp_smith Build Projects 432 Feb 7th, 20 10:36 PM
Enhance Camaro's braking with Power Stop Z23 Brake Kit + CARiD Video carid CARiD.com 0 Dec 17th, 18 07:16 AM
rear brake lines zboss86 Brakes, Suspension & Steering 11 May 6th, 18 12:40 PM
Brake fittings 3d cad Brakes, Suspension & Steering 2 Mar 21st, 18 04:28 AM
69 Camaro Rear Brake Conversion with Mini Tub Kit Camaro1969 Brakes, Suspension & Steering 4 Dec 8th, 17 05:04 PM
