Adjusting ride height - Team Camaro Tech
 4Likes
  • 3 Post By dyno jonn
  • 1 Post By SoCal805
post #1 of 13 (permalink) Old Apr 30th, 19, 08:03 AM Thread Starter
Ok, this may sound like a dumb question, but I'm curious enough to ask. Very often we hear about guys wishing their leaf-spring car was a half inch higher or maybe one side is a slightly different height than the other. So here's the dumb question:
Could you use a coil over with a very low spring rate in place of a regular shock to fine tune your ride height? I know all about air shocks and know that they were designed to boost a sagging rear when the car is overloaded, but why couldn't somebody come up with an adjustable height shock that have you an inch of play or so without drastically impairing the ride?
I don't know the exact mechanical properties of an air shock, but it seems to lift or extend the shock with no give. A coilover would theoretically still have some give. Just a dumb question but maybe somebody thinks it's possible?
'69 LeMans Blue Coupe, White Interior, 030" over 454, Super T10 4-Speed, Holley 4150, Pertronix Ignition
CompCams XS274S, 781 Oval Port Heads, PYPES Full 3" SS Exhaust, Hooker Comp Headers, Wilwood Calipers/MC
JGC Steering Box, Helix Uppers/Lowers, ProForged BJs, SpeedHut Gauges, MOMO Steering Wheel, Budnik 17" Wheels
57vette is offline
post #2 of 13 (permalink) Old Apr 30th, 19, 08:40 AM
Re: Adjusting ride height
To raise one side or both side up 1/2", without going to a taller tire, you can use a block under the leaf spring. They are sold in various thickness 1/4" to 3". Some have added just 1 side if they have a sagging side
Generally people use blocks above leaf (raises axle housing) to lower but you can do the opposite and use them to raise the car by putting them above the leaf spring on the higher side.
Fairly simple to install and about $15 for a block
I got mine at Speedway
SoCal805 is offline
post #3 of 13 (permalink) Old Apr 30th, 19, 10:44 AM
Jon
Generally people use blocks above leaf (raises axle housing) to lower but you can do the opposite and use them to raise the car by putting them under the leaf spring.
The only part of that I believe is the part about using blocks for lowering a car. It might work on a truck where the springs are mounted on top of the axle, but this is a Camaro forum.
TJS69, Chevy68 and 57vette like this.
Jon N
dyno jonn is online now
post #4 of 13 (permalink) Old Apr 30th, 19, 11:21 AM Thread Starter
Exactly. Axle perches are welded in place _UNDER_ the axle, so John is right and moving the spring perch to above the axle would only raise the body up the thickness of the axle... about 3" plus the thickness of the perch. At that point there's no way to lower the car as blocks would only raise it more!
Depending on the pitch of the thread, coilovers can move the car up (or down) in fractions of an inch or even an inch. One of the real benefits of a coilover 3 or 4 link setup.
57vette is offline
post #5 of 13 (permalink) Old Apr 30th, 19, 12:37 PM
My bad guys, I did use blocks to lower the Camaro....and to raise my truck but yeah on the Camaro the spring plate is welded to top of axle housing and block won't work to raise the rear
I used shocks with springs on them on my 70 Torino to raise the rear of that car some
57vette likes this.
SoCal805 is offline
post #6 of 13 (permalink) Old Apr 30th, 19, 01:24 PM Thread Starter
How'd that affect the ride? But the spring load wasn't adjustable like a coilover right?
57vette is offline
post #7 of 13 (permalink) Old Apr 30th, 19, 01:39 PM
no these were non adjustable. Just shocks typically used on pick ups or wagons to offset heavier loads that had a fixed coil spring around them. IIRC they were Gabriel shocks, fairly inexpensive
Ride was OK. It raised the back a good 1" over the then blown out stock shocks which for my purposes was all I wanted on the Torino
These were not the ones I used but what they look like
https://www.summitracing.com/parts/g...content=GSAPI1
I don't see them for Camaro application but if the extended and collapsed heights work than one for another type of car and have the correct ends than that could be a option
There are adjustable coil overs (RideTech) for the Camaro
SoCal805 is offline
post #8 of 13 (permalink) Old Apr 30th, 19, 04:50 PM
https://www.jegs.com/i/JEGS+Performa...6%20Suspension
Maybe ?????
68 Camaro~LSx ~all motor
post #9 of 13 (permalink) Old Apr 30th, 19, 05:23 PM
Beth
Do you have to raise it ?
If not just use a block on the side you need to lower to make them equal.
https://www.jegs.com/i/Danny+Bee/294...UaAkpEEALw_wcB
68 Camaro convertible, 6.0 LQ4 with LS3 heads, Vintage Air, 750 street demon carb, eddy perf rpm, GM hot cam, Hooker headers, 4L80e, 12 bolt, 3.55 gears
NashvilleCat is offline
post #10 of 13 (permalink) Old Apr 30th, 19, 05:30 PM
yep, I know a guy who did the PS because his DS sat lower. Basically "lowering" the higher side vs raising the lower side
SoCal805 is offline
post #11 of 13 (permalink) Old Apr 30th, 19, 05:36 PM
Beth
Here's a good deal. $6 each; you can order them one at a time and lower both sides differing amounts if needed :
https://www.speedwaymotors.com/Speed...lock,3353.html
post #12 of 13 (permalink) Old May 1st, 19, 11:24 AM Thread Starter
Adding a single or different height lowering blocks with Hotchkis lowering springs would probably be a no-no for me. Might work for guys with their rears way up there. I am dealing with tight tire, exhaust, and fender clearance already. Thats why I was curious about using a coilover with a softer/weaker spring in place of a shock. But I'm OK for the moment, just had to ask the question.
57vette is offline
post #13 of 13 (permalink) Old May 1st, 19, 05:39 PM
If you know the height difference (1/2"??) You could then look/measure under the car to see if putting a block of that thickness between leaf & axle would cause any interference in the areas you note. You would be lowering the high side
As posted Speedway has them in varying thickness and they are very simple to install and are quite inexspensive
Otherwise you could put adjustable coil over shocks and adjust them accordingly to the ride height you want on "each" side. IMHO I would not just do one coil over on one side and whatever shock you have on the other
Obviously there is hundreds of $ difference between the two methods
SoCal805 is offline
Ride height issue RaiderNation67 Brakes, Suspension & Steering 11 Apr 13th, 19 05:50 AM
The proper way to correct steering on 1st Gen w/o going overboard Nick_R_23 Brakes, Suspension & Steering 21 Nov 7th, 18 08:31 PM
Confused about levelling the front ride height with Eibach springs Markus Brakes, Suspension & Steering 3 Feb 25th, 18 10:38 AM
need more rear ride height cblackmon Brakes, Suspension & Steering 8 Dec 23rd, 17 05:25 AM
Global West L2 ride height Grifter Brakes, Suspension & Steering 0 Nov 29th, 17 03:58 PM
