Brake hardware needed - Team Camaro Tech
post #1 of 4 (permalink) Old May 6th, 19, 10:36 AM Thread Starter
Chris
Hello,
I can not locate 2 of the four wheel cylinder links (the ~1" long rod that goes from the wheel cylinder to the brake shoe) Had the axle at the driveline shop for a week being upgraded and not sure if my kids "made something" with them or they got swept up in the trash.
I called a few places and no luck,, Can not locate a part number for a 69 12 bolt, 9.5 brakes... short of walking the pick apart looking for something compatible,, does anyone know were to purchase a set or does anyone have a few after a brake upgrade that i could buy???
I did find dome for other older 12 bolts but it say for 11-12" drums
Thanks in advance
chris3353 is offline
post #2 of 4 (permalink) Old May 6th, 19, 12:46 PM Thread Starter
Chris
Re: Brake hardware needed
I believe i found them at orielies, specs are the same but not listed for my car.
post #3 of 4 (permalink) Old May 6th, 19, 12:56 PM
Beth
Inline tube has almost everything for stock brakes, here's your pin :
https://www.inlinetube.com/products/BAF101
68 Camaro convertible, 6.0 LQ4 with LS3 heads, Vintage Air, 750 street demon carb, eddy perf rpm, GM hot cam, Hooker headers, 4L80e, 12 bolt, 3.55 gears
NashvilleCat is offline
post #4 of 4 (permalink) Old May 6th, 19, 10:14 PM Thread Starter
Chris
thank you,,
Enhance Camaro's braking with Power Stop Z23 Brake Kit + CARiD Video carid CARiD.com 0 Dec 17th, 18 07:16 AM
Brake line question Cunning69 Brakes, Suspension & Steering 8 Aug 3rd, 18 06:53 AM
More Rotor & Brake Pad Kits RockAuto RockAuto 0 Jul 26th, 18 03:24 PM
rear brake lines zboss86 Brakes, Suspension & Steering 11 May 6th, 18 12:40 PM
69 Camaro Rear Brake Conversion with Mini Tub Kit Camaro1969 Brakes, Suspension & Steering 4 Dec 8th, 17 05:04 PM
