pedal assy bracket - Team Camaro Tech
post #1 of 7 (permalink) Old May 7th, 19, 11:15 PM Thread Starter
pedal assy bracket
It looks like the pedal assy bracket is the same for 67 and 68 and different for the 69. 3918739 part for 67-8 and 3950064 for 69. Anybody know if they interchange, or what the difference is. Will the early bracket and pedals fit the 69?
Thank You
Charles
Charles Martin is offline
post #2 of 7 (permalink) Old May 8th, 19, 10:19 AM
Red face Re: pedal assy bracket
Are we talking automatic or stick shift pedals ? On Classic Industries website, they show for an automatic that the pedal only is the same for 67-69's. They also show the complete assembly for 67-68. I can only assume the difference is in the mounting, as the 67-68's have the same dash and the 69's have a different dash.
https://www.classicindustries.com/sh...brake%20pedals
TJS69 is offline
post #3 of 7 (permalink) Old May 8th, 19, 12:28 PM Thread Starter
Is for a std transmission, A friend is converting from an automatic to a std transmission
post #4 of 7 (permalink) Old May 8th, 19, 07:40 PM
I might be wrong (well probably wrong) but the 69 may have a bracket or mount for the neutral safety starter switch. 67s and 68s didn't have them.
Old Dad's 67 is offline
post #5 of 7 (permalink) Old May 9th, 19, 02:37 PM
Simon
slazisme is offline
post #6 of 7 (permalink) Old May 9th, 19, 02:39 PM
Simon
Opps wrong posting.
slazisme is offline
post #7 of 7 (permalink) Old May 10th, 19, 09:10 PM
@Charles Martin
Your friend may have already figured it out, but this part doesn't need to be swapped for the conversion to manual.
Drive by wire Gas Pedal Assy Sixty8Camaro LSx Swap 8 Apr 12th, 19 11:11 AM
68 6-cyl gas pedal alignment Raiph Camaro Tech 9 Oct 14th, 18 04:50 PM
Accelerator rod firewall support bracket replace abstron Restoration Corner 8 Aug 3rd, 18 04:48 PM
Rear parking brake cable bracket ??? daven1256 Brakes, Suspension & Steering 3 Mar 24th, 18 08:27 PM
