Unable to remove front Leaf Spring Bolt - Team Camaro Tech
post #1 of 7 (permalink) Old May 14th, 19, 05:32 PM Thread Starter
Bobby
Installing BMR Subframe Connectors and need to remove the bolt at the front location of the leaf spring but it is just turning and not coming out, did I break a weldnut inside?
Will I have to drill an access hole in the top to remove the bolt?
My YouTube LS3 Engine Swap Page
My LS3 Engine Swap Thread
Sixty8Camaro is offline
post #2 of 7 (permalink) Old May 14th, 19, 05:44 PM
Darin
ilikeike's Avatar
It’s just a nut plate.
Read what it says in the description . https://www.heartbeatcitycamaro.com/...GM%23-3992755/
1968 Butternut Coupe,
421" Dart SHP block
TKO 600 RR
Dutchman 9" w/3.70
Global West arms
Budnik wheels
ilikeike is offline
post #3 of 7 (permalink) Old May 14th, 19, 06:03 PM
Jeff
Re: Unable to remove front Leaf Spring Bolt
This is really common...google search ending with camaros.net brought up a bunch of threads...hope this helps. Does not require drilling a hole but it's gonna s*ck!
https://www.camaros.net/forums/16-br...g-bracket.html
SC42 is offline
post #4 of 7 (permalink) Old May 14th, 19, 06:12 PM Thread Starter
Bobby
Thanks for the link, still confused how to get but will crawl back under there tomorrow and take a closer look?
Will have to see if I can find anything on YouTube? If not maybe I need to create one?
post #5 of 7 (permalink) Old May 14th, 19, 06:24 PM
I got lucky wedging a large long screwdriver in there to hold the nut side....not easy, lots of cussing, and about 3 beers
68 Camaro~LSx ~all motor
post #6 of 7 (permalink) Old May 14th, 19, 06:44 PM Thread Starter
Bobby
Iíll definitely try wedging a screwdriver in there and soak it with some PB Blaster ahead of time?
post #7 of 7 (permalink) Old May 14th, 19, 07:08 PM
Darin
ilikeike's Avatar
Wedge a driver like posted , cut it it off however get the pocket out of the way and install good new ones so it doesn’t happen again.
Torque to 35#.
421" Dart SHP block
TKO 600 RR
Dutchman 9" w/3.70
Global West arms
Budnik wheels
ilikeike is offline
Leaf Spring Front Perch Question Domano 68 Brakes, Suspension & Steering 7 Dec 10th, 18 04:49 AM
question about dropping just the front of a leaf spring firstrs Brakes, Suspension & Steering 11 Jan 21st, 12 08:11 AM
Leaf Spring Bushing Install (HELP) Bigwill11 Brakes, Suspension & Steering 4 Feb 27th, 06 11:29 AM
Front leaf spring mounts sjg34 Body Shop 11 Oct 30th, 05 09:10 PM
Adjustment to fender? Winch Body Shop 4 Mar 10th, 02 02:46 PM
