Brake Shoe Smell - Team Camaro Tech
 1Likes
  • 1 Post By allanjs
post #1 of 5 (permalink) Old May 20th, 19, 09:53 PM Thread Starter
Phil
Brake Shoe Smell
Got home from a show Saturday and noticed I smelled brake shoe odor when I pulled in garage. Got out and felt all 4 wheels and it's definitely the drivers rear drum brake. Wasn't smoking, but Rally wheel was very warm to the touch compared to the other 3. What would you guys look for first with this problem? Any help would be greatly appreciated. Some other info that may help. I restored this car 19 years ago and replaced every single component of the entire brake system. The car has about 7500 miles on the restoration. Not one bit of brake problems till this past Saturday.
Bigfish45 is offline
post #2 of 5 (permalink) Old May 20th, 19, 10:05 PM
Beth
Re: Brake Shoe Smell
Brake shoe is dragging and you need to back off the star wheel adjuster.
But it's been so long I need Everett or someone without alzheimer's to tell you how.
68 Camaro convertible, 6.0 LQ4 with LS3 heads, Vintage Air, 750 street demon carb, eddy perf rpm, GM hot cam, Hooker headers, 4L80e, 12 bolt, 3.55 gears
NashvilleCat is offline
post #3 of 5 (permalink) Old May 21st, 19, 04:32 AM
kevin
flat tire is offline
post #4 of 5 (permalink) Old May 21st, 19, 10:05 AM
If you used the parking brake it's possible it's not fully released. If you haven't pulled
the drums for 19 years I would and check everything over.
69-Pace likes this.
my 67' build thread:
allanjs is offline
post #5 of 5 (permalink) Old May 21st, 19, 10:28 AM
OP
likely the self adjuster on that side has adjusted to far or your parking brake is not fully releasing.
Take tire and drum off to inspect. You likely need to hit the parts with some brake cleaner and if the shoes got glazed rub them with some emery cloth
You may need to "loosen" the brake adjuster to get the drum off which means you need to use a screw driver to push the clip away from the star so you can back the star off enough to then get the drum off using a brake adjuster tool
19 year old brake job may just need some clean up attention with the low mileage you have put on the brake system
SoCal805 is offline
brake shoe help keithl1967 Brakes, Suspension & Steering 11 Apr 27th, 15 04:10 PM
Camaro Brake Fluid silicone vs Dot 5 chris tucker Brakes, Suspension & Steering 10 Feb 13th, 12 08:36 PM
Free Wilwood Master Upgrade in our Wilwood Brake Packages. ProdigyCustoms Sponsors 1 Feb 16th, 09 02:50 PM
Brakes - what would you choose? The Corvette Doctor Brakes, Suspension & Steering 4 Jan 2nd, 09 09:47 AM
Brake line flare vs. combo valve flare Meanchicken Brakes, Suspension & Steering 3 Jun 3rd, 04 09:32 PM
