Brakes & Sway Bars upgrade for my 1968 LS2 - Team Camaro Tech
 1Likes
  • 1 Post By NashvilleCat
post #1 of 10 (permalink) Old May 23rd, 19, 01:30 AM Thread Starter
majj
Brakes and Sway Bars upgrade for my 1968 LS2
Hello all, I just did a full build / swap from a 350ci to an LS2. Car is much more powerful. I'm only going to be driving it on the street, no drag/race etc..
I'm not sure which brakes the previous owner had installed, but I definitely need better brakes now. Did a 1-3 pull and had to stop quickly... thats when i knew i needed better brakes lol.
Front
Rear
Sorry for my ignorance, i'm more experienced with JDMs vs muscle so if you could please advise on:
1- what Brake upgrades or Kits to get (I have 17" America Racing Wheels)
2- Do I need front & rear, or just front (Street driven)
3- Also, need better handling in turns and was thinking of getting these front Hellwig Sway Bars (https://www.summitracing.com/int/parts/hel-55705)
or Hotchkis full kit (https://www.hotchkis.net/product/196...k=&yr=&md=&sm=)
Much appreciated.
1968 Camaro SS
LS2/T56
RideTech StreetGrip
majj35 is offline
post #2 of 10 (permalink) Old May 23rd, 19, 09:46 AM
Re: Brakes & Sway Bars upgrade for my 1968 LS2
what is the condition of your current disc brakes? (read are pads worn, do you still have rubber brake hoses, when was the last time brake fluid was bleed)
If uncertain....check/replace pads, turn or replace rotors, replace rubber hoses with SS, bleed brake system
With 17" rims you could run a larger diameter rotor and bigger calipers made by several suppliers (Willwood, Baer, SSB, etc)
While Hotchkis makes good stuff....for your described car use you would be fine, IMHO, with just a larger front sway bar (Summit 1 1/8" brand is fine), good shocks. Assume Arm bushings along with ball joints and tie rods are in good shape. If not, replace
SoCal805 is online now
post #3 of 10 (permalink) Old May 23rd, 19, 09:39 PM
Beth
The 2002 Camaro brakes are probably the best bang for the buck
4 wheel 12" rotors; you can get most of the parts from Rockauto.com
You will need 16" wheels or bigger (you are good)
Al (BPOS) has a great write up on the rear brakes:
https://www.camaros.net/forums/16-br...-pictures.html
The front disks can be installed with this adapter plate :
BRP Hot Rods: Brake Kit: 12" F-Body
Just do the front brakes first. They handle 80% of the braking. You can do the rear brakes later if you want to.
I bought a 1-1/8" front sway bar on ebay for $120.
https://www.ebay.com/itm/1967-1969-C...oAAMXQvJVRQgMy
Camaros are not noted for needing a rear sway bar. I think the leaf springs don't allow the rear end to move sideways like coil springs do.
I have a Chevelle and they do need a rear sway bar.
majj35 likes this.
68 Camaro convertible, 6.0 LQ4 with LS3 heads, Vintage Air, 750 street demon carb, eddy perf rpm, GM hot cam, Hooker headers, 4L80e, 12 bolt, 3.55 gears
NashvilleCat is offline
post #4 of 10 (permalink) Old May 24th, 19, 08:36 AM Thread Starter
majj
Re: Brakes and Sway Bars upgrade for my 1968 LS2
Wow , thanks guys for the feedback! Appreciate the help
Sent from my iPhone using Tapatalk
1968 Camaro SS
LS2/T56
RideTech StreetGrip
majj35 is offline
post #5 of 10 (permalink) Old May 24th, 19, 05:37 PM
Chris
130fe's Avatar
Post Re: Brakes & Sway Bars upgrade for my 1968 LS2
Make sure those brakes fit your wheels. The LS1/C5 style brakes calipers stick out past the wheel mounting surface and could cause interference between the caliper and wheel. I have C5 style brakes in mine. I love them but they donít fit every17+Ē wheel.
Chris
1968 Camaro SS coupe, Lemans Blue/medium blue interior
LS3/T56 Ridetech Suspension
130fe is offline
post #6 of 10 (permalink) Old May 24th, 19, 05:40 PM
Beth
The 2002 Camaro brakes will fit under a 17" wheel - and some 16"
post #7 of 10 (permalink) Old May 24th, 19, 05:41 PM Thread Starter
majj
I have the AR105 torq thrust. 17s
1968 Camaro SS
LS2/T56
RideTech StreetGrip
majj35 is offline
post #8 of 10 (permalink) Old May 25th, 19, 07:18 AM
Chris
130fe's Avatar
Beth, it isnít always about the wheel diameter. I am talking about the wheel spoke part. If they arc out then they might fit. Just telling Majj to test fit them first before buying the brakes.
Chris
130fe is offline
post #9 of 10 (permalink) Old Oct 21st, 19, 06:45 AM Thread Starter
majj
Hey guys, so im digging back into this and going with your suggestions to focus on front changes first.
Still need a few advice on parts that I found below
1) Front sway bar from Hellwig (https://www.summitracing.com/int/parts/hel-55705)
Summit support suggested to go with these (https://www.summitracing.com/int/par...t/model/camaro)
2) Front disc kit from Wilwood (https://www.summitracing.com/int/par...t/model/camaro)
or this (https://www.summitracing.com/int/par...t/model/camaro)
Any major difference for a street driven car? sorry for my ignorance.
I have 17 inch wheels.
Are those good enough to help with the wobbly ride & better braking? Just street driven.
Am i missing any complimentary parts that are needed?
Thank you
1968 Camaro SS
LS2/T56
RideTech StreetGrip
majj35 is offline
post #10 of 10 (permalink) Old Oct 21st, 19, 08:49 AM
Andrew
Andrew69's Avatar
For better functionality and better appearance please go no less than 12" rotor on your LS2 Camaro with 17" wheels. Your big wheels need to be framing some awesome brakes. I'm attaching photos of my 12" LS1 Camaro brakes on my '69 Camaro with 16" Torque Thrust II wheels. 16" is the minimum wheel diameter to fit over this brake design.
If you do the work yourself you can possibly do the whole conversion for $1k or less. The LS1 Camaro used a 1" master cylinder so you can use a modern M/C or utilize one from a '70 Corvette 4-wheel disc with 1" bore with an original booster. If you want no booster then a smaller M/C piston is needed. Because you are basically transferring from a 2002 Camaro, engineered by GM, they stop really well. I can share a sketch of the rear brake emergency cable bracket that BPOS shows in his linked instructions above. Please read and consider the links NashvilleCat provided.
Friends don't let friends install insufficient brakes on their Camaro.
ID:	229995   Click image for larger version
ID:	229997   Click image for larger version
Skunk Works
Some photos:
Member # 159
Andrew69 is offline
Tags
big brake, brake upgrade, rotor, sway bars
Brakes what brand upgrade? Pro-Street69Camaro468 Brakes, Suspension & Steering 6 Mar 7th, 09 08:09 PM
Sway bars or not? andy427 Brakes, Suspension & Steering 6 Mar 14th, 06 02:24 PM
Paint recommendations for Leaf springs and Sway bars ray moore Body Shop 12 Apr 30th, 05 09:07 PM
are sway bars optional? BEN-67 Brakes, Suspension & Steering 8 Oct 2nd, 02 08:12 AM
