Rear disc upgrade. M/C too? - Team Camaro Tech
post #1 of 17 (permalink) Old May 24th, 19, 10:56 AM Thread Starter
Brad
I currently have power disc front drum rear on my 68. Im upgrading to rear disc. I know I have to change the proportioning valve, but do I need to change master cylinders as well. I can seem to find a clear answer.
1968 Camaro SS (most likely clone), Coupe 350/TH400 (original 4 spd), 12 bolt, FiTech Easy Street.
A driving work in progress
AFRaider is offline
post #2 of 17 (permalink) Old May 24th, 19, 11:25 AM
Re: Rear disc upgrade. M/C too?
I hope you are not using those metric Cadillac rear brakes. They suck big time....
1959 El Camino project
1957 Buick Caballero project
dhutton is offline
post #3 of 17 (permalink) Old May 24th, 19, 11:41 AM Thread Starter
Brad
Unfortunately, I discovered a cracked spring perch weld, that started leaking after I cleaned the area and a slightly bent rear axle. Guessing the PO hit a curb. I’m replacing it with a new Moser 12 bolt, I haven’t decided if I’m using their economy brake kit or the Wilwood kit.
AFRaider is offline
post #4 of 17 (permalink) Old May 24th, 19, 11:49 AM
If those economy brakes are metric Cadillac calipers just say no.....
dhutton is offline
post #5 of 17 (permalink) Old May 24th, 19, 12:43 PM
Vega$69's Avatar
If you change from disc/drum to disc/disc you will need a different MC
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #6 of 17 (permalink) Old May 24th, 19, 12:44 PM
Vega$69's Avatar
The Caddy Metric work fine if you adjust them correctly. You have to adjust the E-brake before you bleed the calipers.
69 Z28(Sold)
(SOLD)
Vega$69 is offline
post #7 of 17 (permalink) Old May 24th, 19, 01:33 PM
Tim
I think my Right Stuff Detailing big brake kit came with the rear Caddy metrics but I have not installed them yet. Are they really that bad?
1969 Camaro - a gift from the brother-in-law build thread
Shannon4570 is offline
post #8 of 17 (permalink) Old May 24th, 19, 01:40 PM
Darin
ilikeike's Avatar
Whatever you get, get a floating caliper if you do not have floating rear axles.
I had the metrics. They worked. But I hated adjusting them.
1968 Butternut Coupe,
421" Dart SHP block
TKO 600 RR
Dutchman 9" w/3.70
Global West arms
Budnik wheels
ilikeike is online now
post #9 of 17 (permalink) Old May 24th, 19, 03:18 PM
Vega$69's Avatar
You only adjust them when you 1st install them. Everyone I know of that had a problem is because they did not follow the instructions and adjust the e-brake 1st.
GM put them on 100s of thousands of cars over the years.
69 Z28(Sold)
(SOLD)
Vega$69 is offline
post #10 of 17 (permalink) Old May 24th, 19, 03:43 PM
Darin
ilikeike's Avatar
I agree.
It dose take some experience to get those things right.
I figured mine out and had them working fine, but there definitely was a learning curve. I took one caliper completely apart to real understand what was going on with the rachet BS E-brake. I figured it out.
Still, Much ! easier to have the disc with a separate drum e brake.
Like I always say after I complain about them, they work.
421" Dart SHP block
TKO 600 RR
Dutchman 9" w/3.70
Global West arms
Budnik wheels
post #11 of 17 (permalink) Old May 24th, 19, 05:45 PM
Beth
The 1998-2002 Camaro disks are a drum-in-hat design that has a much stronger parking brake.
The only problem is you need two left side backing plates from a junkyard.
68 Camaro convertible, 6.0 LQ4 with LS3 heads, Vintage Air, 750 street demon carb, eddy perf rpm, GM hot cam, Hooker headers, 4L80e, 12 bolt, 3.55 gears
NashvilleCat is offline
post #12 of 17 (permalink) Old May 24th, 19, 05:56 PM Thread Starter
Brad
The Wilwood upgrade is about $250. Maybe I’ll go that route.
Thanks for the info on the MC
AFRaider is offline
post #13 of 17 (permalink) Old May 25th, 19, 06:26 AM
I agree.
I recently had these rear discs installed on my 67 with a new Moser rear end. I have been trying to find the installation instructions and have had no luck. I contacted Moser and they sent me a link to the right stuff web site. If anyone has the instructions they can post a link to I would greatly appreciate it. I want to know how they work and what I can do to adjust them. My car pulls slightly to the left when first applying the brakes and I want to know how to work on these myself. I also have the E brake option. My front brakes are factory 1969 Camaro disc brakes.
Thanks in advance
1967 Camaro
383 stroker
Automatic
Duneit is offline
post #14 of 17 (permalink) Old May 25th, 19, 10:30 AM
Darin
ilikeike's Avatar
Hear are another version of instructions that may help. . https://www.jegs.com/installationins...610_630611.pdf
421" Dart SHP block
TKO 600 RR
Dutchman 9" w/3.70
Global West arms
Budnik wheels
post #15 of 17 (permalink) Old May 27th, 19, 10:10 AM
Thanks! Exactly what I was looking for.
1967 Camaro
383 stroker
Automatic
Duneit is offline
LS1 Rear Disc Install Lots of Pictures BPOS Brakes, Suspension & Steering 85 Apr 1st, 19 12:47 PM
Tire clearance issues on front disc brake upgrade for 67? RSSSfanatic Brakes, Suspension & Steering 12 Jan 8th, 16 04:15 PM
Front Disc, rear drum manual brake master Joe Harrison Brakes, Suspension & Steering 10 Oct 24th, 11 09:11 PM
upgrade to rear disc brakes? 68fan Brakes, Suspension & Steering 2 Jan 10th, 09 08:41 PM
Installing rear disc brakes? ENP Brakes, Suspension & Steering 1 Jan 28th, 06 12:31 AM
