Rear Disc Brake ??? - Team Camaro Tech
post #1 of 8 (permalink) Old May 26th, 19, 05:41 AM Thread Starter
Bruce
Rear Disc Brake ???
Installing a Jegs rear brake conversion on a 69 does the caliper install staggered like the shocks? The directions leave a bit to be desired. After all these years this is my first rear conversion as the rebuilt 12 bolt rear end I got was set up for a disc brake conversion, will see what a difference it makes!!
The Camaro Guy is offline
post #2 of 8 (permalink) Old May 26th, 19, 06:30 AM
Vega$69's Avatar
Re: Rear Disc Brake ???
Yes the calipers are staggered. The instructions appear to be very clear and detailed for the installation.
Adjusting the e-brake is critical before bleeding the brakes. #39 on page 8 of the instructions.
How was the rear axle set up for disc brakes? There is no difference except the backing plates for drums.
Vega$69 is offline
post #3 of 8 (permalink) Old May 26th, 19, 06:53 AM
There is only one way you can install the calipers and keep the bleeder screws at the top. Well almost at the top with those awesome metric calipers....
1959 El Camino project
1957 Buick Caballero project
dhutton is online now
post #4 of 8 (permalink) Old May 26th, 19, 08:44 AM Thread Starter
Bruce
The backing plates and drums were removed when I got the rear end.
post #5 of 8 (permalink) Old May 26th, 19, 09:24 AM
Beth
LOL, Don is a fan of those calipers
68 Camaro convertible, 6.0 LQ4 with LS3 heads, Vintage Air, 750 street demon carb, eddy perf rpm, GM hot cam, Hooker headers, 4L80e, 12 bolt, 3.55 gears
NashvilleCat is offline
post #6 of 8 (permalink) Old May 28th, 19, 07:02 AM Thread Starter
Bruce
Followed the Jegs rear disc conversion directions. The caliper sits to close to the axel causing the front to sit tight to the rotor without the brake pads installed. The relationship and fit of the caliper to the rotor is way off. The caliper bracket is installed on the inboard side facing the axel. Its almost seems like the rotor is not deep enough to center with the caliper. Stumped!!!!
post #7 of 8 (permalink) Old May 28th, 19, 07:51 AM
Darin
ilikeike's Avatar
I'm not sure if this is any help, but I attached a picture of my rear with the brackets still on.
1968 Butternut Coupe,
421" Dart SHP block
TKO 600 RR
Dutchman 9" w/3.70
Global West arms
Budnik wheels
ilikeike is online now
post #8 of 8 (permalink) Old May 28th, 19, 06:59 PM Thread Starter
Bruce
Hey Darin. . . .that's how I did it. Talking with the guys a Jegs, they said sometimes the directions are not updated when some of the components change. We decided to mount the caliper brackets inboard instead, I thought so but wanted to find out if I had the wrong parts, most all the disc brake conversions use GM parts for their kits and are sometimes updated.
Rear disc brake conversion -Proportioning Valve Agitator Brakes, Suspension & Steering 3 Jul 5th, 14 10:57 PM
Rear wheel size question w disc brake Marc Wheels & Tires 2 Dec 7th, 11 05:52 AM
67 rear disc parking brake cable routing help hybryd67 Brakes, Suspension & Steering 0 Jul 26th, 07 06:14 PM
10-bolt Rear Disc Brake Axles gheatly Brakes, Suspension & Steering 8 Jan 18th, 06 12:53 PM
