Power steering gone - Team Camaro Tech
post #1 of 13 (permalink) Old May 26th, 19, 09:44 AM Thread Starter
Power steering gone
Haven't had any issues with the power steering in my '69 since yesterday. It was after some pretty wild fish-tailing (I get no traction now with my 4.11 gears). Checked the fluid level and it's fine. Is it pretty much a no brainer that the pump is bad?
Last edited by 69-Pace; May 26th, 19 at 12:02 PM. Reason: removed giberish characters
Mike's69stroker is offline
post #2 of 13 (permalink) Old May 26th, 19, 09:46 AM Thread Starter
Donít understand the punctuation there
Moderator edit:
Mike some how the character set wasn't set to American English. I deleted the cryptic characters and tried to follow your train of thought. Did you post from a phone or desktop?
post #3 of 13 (permalink) Old May 26th, 19, 10:58 AM
Re: Power steering gone
OP
so does the PS still not work just under normal driving (read not "fish tailing")?
I have seen belts throw when people get all "Gas Monkey" on burnouts....but I assume you checked to see if your belt is still on....and tight
SoCal805 is offline
post #4 of 13 (permalink) Old May 26th, 19, 12:09 PM
69-Pace's Avatar
I would bring it up to temp and then see if you can lock the wheel to the left and hear the pump actually working, then slowly drive in a flat level area like a parking lot can she hold the tight circle or does it wonder away from the tight circle. Then try locking in the other direction. If it wonders out of the lock your not holding pressure and check the fluid level again, you might have a pinhole leak in one of the hoses. Also if you cant hear the pump change under load from idle as someone gently turns the wheel while parked then the belt is either slipping or the pump is bad.
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #5 of 13 (permalink) Old May 26th, 19, 06:13 PM Thread Starter
God, no, I hate to say it, I didn't check the belt, and that in fact was the problem. Duh. In any case, I guess it's best to get a new belt.
post #6 of 13 (permalink) Old May 26th, 19, 06:19 PM Thread Starter
I post from a phone. Never have seen this issue
post #7 of 13 (permalink) Old May 26th, 19, 06:19 PM Thread Starter
Thanks for the help
post #8 of 13 (permalink) Old May 27th, 19, 06:28 AM
69-Pace's Avatar
Check the keyboard setting if it is iOS you can have multiple ones loaded and everything you hit the globe it cycles through them. Not sure what Android does. But until you find it I would avoid punctuation LOL
69-Pace is offline
post #9 of 13 (permalink) Old May 27th, 19, 08:33 AM
I prefer the Goodyear (I think now called Continental) Gatorback belts
SoCal805 is offline
post #10 of 13 (permalink) Old May 27th, 19, 10:10 AM Thread Starter
Cool, I’ll look for one of those
post #11 of 13 (permalink) Old May 27th, 19, 10:48 AM
kevin
you didn't say whether the belt was loose or came off.
if it came off, here is a little trick you can use to keep it on at any rpm
flat tire is offline
post #12 of 13 (permalink) Old May 28th, 19, 06:14 PM Thread Starter
Yeah it came off, and I'm having a hard time keeping it on. I believe that I am tightening the belt when I rotate the pump assembly upwards, but maybe I'm not torquing it hard enough on it.:.. let's face it, i suck at this stuff, but I should at least be able to tighten a dam belt!
post #13 of 13 (permalink) Old May 28th, 19, 06:18 PM Thread Starter
I will try not to use punctuation here. When I loosen one of the bolts holding the pulley assembly in place, I am able to rotate the thing upwards and it looks like I am tightening the belt in the process. Maybe I am not pushing hard enough on it?
Are jets my next step? 4Speed67CamaroRS Engine 19 Apr 10th, 18 10:37 AM
Need help with quadrajet DDOLES Performance 17 Mar 30th, 18 08:34 PM
advise on power steering vs Power Rack ittybittyfds Brakes, Suspension & Steering 12 Jul 12th, 13 07:11 AM
IROC performance in a 1st Gen Steering box 69rad Brakes, Suspension & Steering 16 Jun 25th, 12 12:20 AM
Pitman Arm Apex Brakes, Suspension & Steering 10 Feb 17th, 10 08:40 PM
