ride tech front shocks - Team Camaro Tech
 1Likes
  • 1 Post By Vega
post #1 of 10 (permalink) Old May 27th, 19, 06:32 PM Thread Starter
Probationer
Hi guys,I have 69 with a big block that's crushing my ridetech coil over shocks with big block springs. anyone else run across this issue? thanks
bad rat is offline
post #2 of 10 (permalink) Old May 27th, 19, 07:14 PM
Chris
130fe's Avatar
Re: ride tech front shocks
What do you mean "crushing"? Are you running out of threads and can't get anymore height or what? What spring (LB) are you currently running? it is written on one end of the coils.
Chris
1968 Camaro SS coupe, Lemans Blue/medium blue interior
LS3/T56 Ridetech Suspension
130fe is online now
post #3 of 10 (permalink) Old May 27th, 19, 07:32 PM Thread Starter
Probationer
If im looking at it correctly they are 800lb springs. Having a hard time telling but it fells like the weight of the car is bottoming out the shock
bad rat is offline
post #4 of 10 (permalink) Old May 27th, 19, 07:34 PM Thread Starter
Probationer
Cant really adjust ride height with these shocks. the adjuster tightens by hand
bad rat is offline
post #5 of 10 (permalink) Old May 28th, 19, 04:05 AM
Brett
Do you have 2" drop spindles? Do you have tubular control arms? Both of those will drop the car too low. My springs are 600# and they don't hardly compress at all. It is hard to think that with 800# springs it is actually crushing them. Sounds like something else is going on.....
Brett......
Rockets Up In 2020!
Brettallen59 is offline
post #6 of 10 (permalink) Old May 28th, 19, 05:56 AM
Vega$69's Avatar
You should not be able to adjust by hand. You need a spring nut adjustment tool to turn the adjustment nuts in the shock body.
How far from the bottom of the Shock is the nut now?
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #7 of 10 (permalink) Old May 28th, 19, 08:23 AM Thread Starter
Probationer
I was able to spin the nut up 1.5" by hand. I don't think they offer an adjustment wrench for there shocks.
bad rat is offline
post #8 of 10 (permalink) Old May 28th, 19, 10:32 AM
https://www.ridetech.com/products/ac...panner-wrench/
my 67' build thread:
allanjs is offline
post #9 of 10 (permalink) Old May 28th, 19, 10:34 AM
Vega$69's Avatar
If you have only tightened by hand then you are correct it is probably bottoming out the shock you need to use a wrench to compress the spring to ride height.
130fe likes this.
69 Z28(Sold)
(SOLD)
Vega$69 is offline
post #10 of 10 (permalink) Old May 28th, 19, 12:12 PM Thread Starter
Probationer
Thanks guys ,got one ordered.
bad rat is offline
