Steering Arm selection? - Team Camaro Tech
post #1 of 5 (permalink) Old May 31st, 19, 07:28 PM Thread Starter
Robert
rtchaney's Avatar
I've got a long arm on my box but curious about the Akermann affect from differing steering arms. Is one length better or worse for street or track driving?
1968, 5 speed, Vintage Air Gen IV, American Auto Wire Update Series, Champion 4 Core Rad, BMR front w/ Koni's, BP Roller 383, Posi 8.2", Solid Frame Bushings
rtchaney is offline
post #2 of 5 (permalink) Old May 31st, 19, 07:53 PM
scblucam's Avatar
Re: Steering Arm selection?
Quote from David Pozzi:
The 12.7:1 can be too quick if you have the shortest outer arms and the long pitman.
My favorite setup is a 12.7:1 box with short pitman and short outer arms
Not sure it answers your question but maybe a direction. Check out his site for lots of info.
68 302 M20 - 85 IROC Z
scblucam is offline
post #3 of 5 (permalink) Old May 31st, 19, 08:07 PM Thread Starter
Robert
rtchaney's Avatar
Well, I've got 10.5/1, the longest pitman and the shortest arms... 😁
rtchaney is offline
post #4 of 5 (permalink) Old May 31st, 19, 10:49 PM
David Pozzi
davidpozzi's Avatar
The long outer arms should increase Ackerman a little. I havenít checked the numbers for a first gen Ackerman but I suspect being rear steer, itís not bad & much better than a second gen front steer.
davidpozzi is offline
post #5 of 5 (permalink) Old Jun 2nd, 19, 04:08 AM Thread Starter
Robert
rtchaney's Avatar
The long outer arms should increase Ackerman a little. I haven’t checked the numbers for a first gen Ackerman but I suspect being rear steer, it’s not bad & much better than a second gen front steer.
Thank you.
rtchaney is offline
