Drilled/Slotted rotors - Team Camaro Tech
 1Likes
  • 1 Post By NashvilleCat
post #1 of 4 (permalink) Old Jun 3rd, 19, 08:16 PM Thread Starter
Dean
islanddean's Avatar
Hey guys. I’ve got a 67 Camaro with front disc brakes and I’d like to put drilled and slotted rotors on the front. Problem is I can’t seem to find a set and was hoping someone might be able to direct me.
1967 Camaro Convertible with a 327, TH350transmission, Edelbrock 1406 600cfm carb, Edelbrock 1721 fuel pump & 2701 intake.
"The true measure of a man is not where he stands in time of comfort and convenience but where he stands in time of challenge and controversy."
MLK
islanddean is offline
post #2 of 4 (permalink) Old Jun 3rd, 19, 09:27 PM
Re: Drilled/Slotted rotors
Drill and/or Slotted (it is usually one or the other) rotors are an old sports car racing trick to get the gas given off by roasted friction pucks so that they would bite better. (they assumed at the time without any observed evidence that the pucks would hydroplane like a big slick on a wet roar). Keep in mind the disc brakes they were using were WWII surplus disc brakes off of fighter planes. The composition of the friction material has greatly changed with improvements in adhesives and friction material. Most brake companies do not recommend slotted and drilled rotors any more as the machining of the rotor to vent gas to the interior promotes cracks that will eventually destroy the rotor.
If you have a conversion kit that utelizes 1969-72 GM A-Body parts then this kit will work:
https://www.jegs.com/i/Stainless+Ste...caAhUgEALw_wcB
MPB and others offer similar parts
Big Dave
Larger Dave is offline
post #3 of 4 (permalink) Old Jun 4th, 19, 02:46 AM
Brett
What about these? Drill and Slotted Rotors
Or actually these with hubs Drilled and Slotted Rotors
Brett....
Rockets Up In 2020!
Brettallen59 is offline
post #4 of 4 (permalink) Old Jun 4th, 19, 03:08 AM
Beth
Rockauto has them under the "powerstop' brand
wireboy355 likes this.
68 Camaro convertible, 6.0 LQ4 with LS3 heads, Vintage Air, 750 street demon carb, eddy perf rpm, GM hot cam, Hooker headers, 4L80e, 12 bolt, 3.55 gears
NashvilleCat is offline
