missing nut - Team Camaro Tech
post #1 of 7 (permalink) Old Jun 4th, 19, 04:51 PM Thread Starter
missing nut
I am trying to put the traction control rod back on my 67 Camaro. Nut insert or whatever they call them is missing in the frame for the front bracket. No way can get a regular nut on the bolt. Any idea exactly what it is called and where can I get one. Can I get away without using that bolt location and just use the 2 floor bolts.
Thank You
Charles
Charles Martin is offline
post #2 of 7 (permalink) Old Jun 4th, 19, 06:06 PM
Garth
Re: missing nut
A "rivnut" should work https://www.ebay.com/itm/Rivet-nuts-...YAAOSwfk9bX3mO What size hole is in the frame rail ? I would NOT recommend using the radius rod with just the 2 pan bolts.
Garfields Maro is offline
post #3 of 7 (permalink) Old Jun 4th, 19, 10:34 PM Thread Starter
Re: missing nut
Looks like those take a special tool to install, and looks like the tool is pretty expensive as in about 275.00.
post #4 of 7 (permalink) Old Jun 4th, 19, 10:46 PM
Garth
Re: missing nut
No, I've never did any larger than 1/4", but it just takes a standard nut and bolt. I presume it'd work for larger sizes. Check YouTube.
That's the first vid that came up. You can check others...
post #5 of 7 (permalink) Old Jun 5th, 19, 08:58 AM
Frank
Re: missing nut
This is the nutsert tool I use and i've done as big as 3/8", mostly 1/4" & 5/16" but 3/8" is doable
https://www.summitracing.com/parts/w...SABEgJVpvD_BwE
'68 Camaro 454, 4sp
Just 1 More is offline
post #6 of 7 (permalink) Old Jun 5th, 19, 10:20 AM
Vega$69's Avatar
Re: missing nut
You can insert a rivnut without the tool using a bolt and flat washers.
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #7 of 7 (permalink) Old Jun 5th, 19, 01:13 PM Thread Starter
Re: missing nut
Thanks all, have some on the way. Hopefully can get one in, then the next problem will be the drivers side. Back in the day GM recommended 2 bars left and right. Don't remember just what i did for the front bracket, but do remember had a 1/4 in steel plate on top of the floor for reinforcement, probably overkill, Been trying to find a LH Firebird bracket, but no luck so far to see if that works. Thinking that I just used the floor bolts at that time.
