1/2 size Detroit speed body bushings Problems - Team Camaro Tech
 1Likes
  • 1 Post By 69L48Z27
post #1 of 14 (permalink) Old Jun 4th, 19, 07:29 PM Thread Starter
Apprentice
Thomas
OK so I bought the half size Detroit speed aluminum body bushings installed the sub frame everything looks great until I go to install the transmission crossmember. It will not fit the body is too close to the frame. short of cutting my new floor up I was wondering if anybody Else had these issues and how you fixed it any help would be great thanks you guys
tosty is offline
post #2 of 14 (permalink) Old Jun 4th, 19, 08:55 PM
Re: 1/2 size Detroit speed body bushings Problems
What trans?
3d cad is offline
post #3 of 14 (permalink) Old Jun 4th, 19, 09:31 PM Thread Starter
Apprentice
Thomas
M 22 Muncie
tosty is offline
post #4 of 14 (permalink) Old Jun 4th, 19, 09:32 PM Thread Starter
Apprentice
Thomas
I was planning on using the factory crossmember
tosty is offline
post #5 of 14 (permalink) Old Jun 4th, 19, 09:40 PM
Red face Re: 1/2 size Detroit speed body bushings Problems
Loosen up your subframe bushings, install your crossmember, then tighten your subframe bushings back up. It is common that the use of a persuader is needed if you don't loosen the subframe mounts, and that is with STOCK bushings.
TJS69 is offline
post #6 of 14 (permalink) Old Jun 5th, 19, 06:00 AM
Vega$69's Avatar
The X is very tight with stock height bushings. It's obvious that 1/2 size bushing would cause this issue.
As above loosen the bolts enough to get the clearance need to install the X or buy a crossmember that bolts in.
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #7 of 14 (permalink) Old Jun 6th, 19, 04:27 PM Thread Starter
Apprentice
Thomas
So I can’t just loosen up the body bolts because I have welded in subframe connectors any recommendations on different crossmembers
tosty is offline
post #8 of 14 (permalink) Old Jun 6th, 19, 05:53 PM
Originally Posted by tosty View Post
So I canít just loosen up the body bolts because I have welded in subframe connectors any recommendations on different crossmembers
https://www.speedwaymotors.com/Searc...20Crossmembers
68 Camaro~LSx ~all motor
post #9 of 14 (permalink) Old Jun 6th, 19, 06:01 PM
Garth
Are the frame connectors welded to the floor? If not, back the bolts out and use the weight of the car to pull the back of the subframe down.
130fe likes this.
1969 Camaro SS 350 LeMans Blue
2015 Z/28 - Red
2 x 1967 R/Tís
1977 Power Wagon
1978 Liíl Red Express
69L48Z27 is offline
post #10 of 14 (permalink) Old Jun 6th, 19, 07:01 PM Thread Starter
Apprentice
Thomas
Yes the sub frame connectors are welded From the four-lane bars to the floor to the front frame I was thinking I may try a g-force
tosty is offline
post #11 of 14 (permalink) Old Jun 6th, 19, 07:12 PM Thread Starter
Apprentice
Thomas
Like this one
tosty is offline
post #12 of 14 (permalink) Old Jun 6th, 19, 09:08 PM
Vega$69's Avatar
X2 on the G Force
69 Z28(Sold)
(SOLD)
Vega$69 is offline
post #13 of 14 (permalink) Old Jun 6th, 19, 09:58 PM Thread Starter
Apprentice
Thomas
Not to sound dumb but what does X2 on the G Force mean good or bad?
tosty is offline
post #14 of 14 (permalink) Old Jun 27th, 19, 10:48 AM
David Pozzi
davidpozzi's Avatar
X2 means times two. It means heís the second one to agree.
davidpozzi is offline
