Spindle Bolt?? - Team Camaro Tech
post #1 of 19 (permalink) Old Jun 4th, 19, 11:00 PM Thread Starter
Chris
Spindle Bolt??
I'm assembling the front suspension and have new hardware and fasteners for everything except the stubby 5/8-18 x 7/8" bolt that goes through the backing plate and caliper bracket and threads into the spindle. I've checked all the suppliers, NPD, Classic, Rick's, Year One, etc......can't find it. Checked my assembly manual for the torque spec, can't find that either.
Any of you know where I can get some grade 8 replacements and how tight they should be?
racinrod67 is offline
post #2 of 19 (permalink) Old Jun 4th, 19, 11:40 PM
Beth
Re: Spindle Bolt??
https://www.speedwaymotors.com/1964-...olt,37214.html
68 Camaro convertible, 6.0 LQ4 with LS3 heads, Vintage Air, 750 street demon carb, eddy perf rpm, GM hot cam, Hooker headers, 4L80e, 12 bolt, 3.55 gears
NashvilleCat is offline
post #3 of 19 (permalink) Old Jun 5th, 19, 05:39 AM
Bruce
Re: Spindle Bolt??
NPD, Ricks, Classic Camaro, Speedway
The Camaro Guy is offline
post #4 of 19 (permalink) Old Jun 5th, 19, 05:51 AM
Ed
Re: Spindle Bolt??
If there is nothing special about the bolt you could try Lowes or Tractor Supply.
ZEN357 is offline
post #5 of 19 (permalink) Old Jun 5th, 19, 09:41 PM Thread Starter
Chris
Re: Spindle Bolt??
Originally Posted by NashvilleCat View Post
Perfect, thank you....that's it. Anybody know the torque value??
post #6 of 19 (permalink) Old Jul 4th, 19, 09:06 AM
Apprentice
Re: Spindle Bolt??
Didn't the OEM have grade 8 markings on the head? That bolt from Speedway is the Chinese version that comes with their spindles, the head thickness is reduced for some unknown reason, I don't trust unmarked Chinese bolts. A normal gr8 bolt with proper markings fits correctly.
Yes I realize I'm late to this discussion but those bolts are not good
oldnovice is offline
post #7 of 19 (permalink) Old Jul 4th, 19, 10:21 AM
Jon
Re: Spindle Bolt??
bolt.com/pages/catalog/bolts/tighteningtorque
Jon N
dyno jonn is online now
post #8 of 19 (permalink) Old Jul 4th, 19, 10:23 AM
kevin
Re: Spindle Bolt??
ace hardware. nothing that short? get a longer one and cut it. put a nut beyond the cut . cut. grind rough edges. remove nut
flat tire is offline
post #9 of 19 (permalink) Old Jul 4th, 19, 10:31 AM
Chick
68camaroz28's Avatar
Re: Spindle Bolt??
Do u have your originals? I glass beaded our originals and had them replated.
Chick
68, 69, & 2015 Z/28's
69 Nova's L34 Father/Son & L78 Surv purch-new
67, 68, & 2015 Z06 Corvettes
Our 68Z Restoration
68camaroz28 is offline
post #10 of 19 (permalink) Old Jul 4th, 19, 03:44 PM
Lynn
Re: Spindle Bolt??
The only issue with a grade 8 bolt from the hardware store is that the head is too thick and will interfere with the rotor.
You can special order them or do what I did. Trip to Ace, two short grade 8 bolts. Grind the head down for clearance.
Lynn
bilodeaulynn is offline
post #11 of 19 (permalink) Old Jul 4th, 19, 04:56 PM
Apprentice
Re: Spindle Bolt??
I use them all the time, does not hit the rotors.
post #12 of 19 (permalink) Old Jul 4th, 19, 08:37 PM
Lynn
Re: Spindle Bolt??
Then I have different spindles than you do. I ground them off, and one still rubbed just a bit. Had to remove it and grind some more.
Maybe because I was using modified drum brake spindles. I THOUGHT they were the same after removing the excess material from the drum brake spindles. Maybe not.
Lynn
post #13 of 19 (permalink) Old Jul 4th, 19, 08:42 PM
Lynn
Re: Spindle Bolt??
Not a great pic, but this is an original 69 spindle assembly. The bolt in question is up at the top. The head is thinner than the two standard bolts below that bold to the steering arm.
Lynn
post #14 of 19 (permalink) Old Jul 5th, 19, 09:03 AM
Ben
Re: Spindle Bolt??
that's one rough looking spindle
bhodgdon400 is offline
post #15 of 19 (permalink) Old Jul 5th, 19, 03:14 PM
Apprentice
Re: Spindle Bolt??
Clears with a little over an 1/8"
I use 5/8"-18X1" grade 8 bolts. Buy from any good supplier, not Chinese auto parts.
I would never use a cut up drum spindle or that Chinese reduced head unmarked bolt..
