Front suspension - Team Camaro Tech
 4Likes
post #1 of 23 (permalink) Old Jun 7th, 19, 07:58 PM Thread Starter
RDW
Bob
Front suspension
Iíve been doing a lot of reading and Iím still left with the same question. What is the best way to lower the stance on the front of my 67
67 Camaro coupe 327 automatic
78 RS Camaro 350 automatic (sold)
RDW is offline
post #2 of 23 (permalink) Old Jun 7th, 19, 08:57 PM
Beth
Re: Front suspension
Moog 6308 IMHO
https://www.camaros.net/forums/16-br...08-6320-a.html
68 Camaro convertible, 6.0 LQ4 with LS3 heads, Vintage Air, 750 street demon carb, eddy perf rpm, GM hot cam, Hooker headers, 4L80e, 12 bolt, 3.55 gears
NashvilleCat is offline
post #3 of 23 (permalink) Old Jun 8th, 19, 06:26 AM Thread Starter
RDW
Bob
RDW is offline
post #4 of 23 (permalink) Old Jun 8th, 19, 09:09 AM
FWIW I used the RideTech progressive lowering spring. Got a 1 5/8" drop
https://www.summitracing.com/parts/a...t/model/camaro
SoCal805 is online now
post #5 of 23 (permalink) Old Jun 8th, 19, 10:29 AM
Mine was high after rebuilding frontend....money was tight.
I ended up cutting 1 full coil and got a 2"-2.25" drop. Slightly stiffer frontend ? I couldn't tell.
and 1.54 60' off the footbrake...I don't think the car know either
[ATTACH][/ATTACH]
Name:	Inked10.96 run_LI.jpg
68 Camaro~LSx ~all motor
post #6 of 23 (permalink) Old Jun 12th, 19, 02:11 PM
T.C.
Lowering Springs or Coilover Shocks
BMR Suspension is offline
post #7 of 23 (permalink) Old Jun 12th, 19, 02:33 PM
Bob, More info is needed to give informed suggestions. What are you starting with ? What engine,
air conditioning, convertible, coupe? Any mods that have been made. Tire size. Current pics.
How low do you want to go?
my 67' build thread:
allanjs is offline
post #8 of 23 (permalink) Old Jun 13th, 19, 01:34 PM
David Pozzi
davidpozzi's Avatar
I'm with Al. Need to know what you are doing with the car, street cruiser or autocross? Carving canyon roads or highway use? Also any engine mods/swaps. 6308 is a Z/28 spring and works great if front end weight is not too high and you are not going to autocross a lot or have radial TA tires & not something more grippy.
davidpozzi is offline
post #9 of 23 (permalink) Old Jun 13th, 19, 02:27 PM
The answer to his question as to the fastest easiest and cheapest way to lower your Camaro is to let the air out of the tires.
Big Dave
BMR Suspension likes this.
Larger Dave is offline
post #10 of 23 (permalink) Old Jun 13th, 19, 06:43 PM
Vega$69's Avatar
Big Dave
And always thought the answer was get a fat chick GF in the passenger seat.
No offense intended.
bhodgdon400 likes this.
Vega$69 is offline
post #11 of 23 (permalink) Old Jun 13th, 19, 06:59 PM Thread Starter
RDW
Bob
Sorry I put a new ridetech 4 link suspension on the rear and the front sits to high. I have a 327 with no a/c . The tires on the front are 205/70/15 but the issue is the car seems to sit quite high above the tire. Also I tried letting all the air out of the tires, I still didnít like the stance and it didnít ride very well.
RDW is offline
post #12 of 23 (permalink) Old Jun 13th, 19, 07:22 PM
scblucam's Avatar
That sounds serious but I THINK NOT.
Why not try Ridetech up front.
68 302 M20 - 85 IROC Z
scblucam is offline
post #13 of 23 (permalink) Old Jun 13th, 19, 07:22 PM
I would use the Ridetech progressive rate springs.
1959 El Camino project
1957 Buick Caballero project
dhutton is online now
post #14 of 23 (permalink) Old Jun 13th, 19, 07:27 PM
Tires don't hold the car up, nor shocks, only the spring/air bag holds the weight off of the ground. if you think your spring holds your weight up to high add a lot more weight (like a BBC) or get a shorter spring.
Springs are sold by spring rate (the ability to hold up one hundred pounds one inch high is the spring rate). but it has a free height )no load height, a diameter and a coil diameter that along with how the spring is wound (flat bottom, pig tail, full coil that fits in a pocket on the A-arm) are what separates the numbers in the Moog catalog.
You want one just like you have now (don't ask I have no more idea what you have than you do) only shorter to lower your car's ride height.
Big Dave
post #15 of 23 (permalink) Old Jun 13th, 19, 08:33 PM
scblucam's Avatar
Unless coil overs. Technically still a spring but adjustable.
scblucam is offline
