69 Brake Booster Pins - Team Camaro Tech
post #1 of 4 (permalink) Old Jun 9th, 19, 10:38 PM Thread Starter
Phil
I bought a reproduction power disc brake booster for my 69 Camaro. It came with 2 booster to master cylinder piston pins. One short and one long. The reproduction 309 master cylinder came with a spud, stub or extension (whatever it's called) in the piston hole. The short pin and the stub measures the same length as the long pin without the stub. Why would this booster kit come with a long pin and a short pin? Which should I use, long pin without spud or short pin with the spud? Please look at attached picture.
Bigfish45 is offline
post #2 of 4 (permalink) Old Jun 9th, 19, 11:06 PM
Beth
Re: 69 Brake Booster Pins
This should help :
https://techtalk.mpbrakes.com/how-to...r-cylinder-gap
68 Camaro convertible, 6.0 LQ4 with LS3 heads, Vintage Air, 750 street demon carb, eddy perf rpm, GM hot cam, Hooker headers, 4L80e, 12 bolt, 3.55 gears
NashvilleCat is offline
post #3 of 4 (permalink) Old Jun 10th, 19, 02:01 AM
Garth
Just use the long rod (pin). The booster came with both long and short, depending on what MC is being used. The MC came with a "spud", to be used if the booster has a short rod, or to remove the spud if the booster came with a long rod. Like you say, both set-ups are the same length.
Garfields Maro is offline
post #4 of 4 (permalink) Old Jun 10th, 19, 10:04 AM Thread Starter
Phil
Well I've ran into an issue. With the short rod inserted into the booster and the "spud" inserted in the master cylinder, the mounting flange of the master cylinder will not mate with the mounting surface of the booster. If I push the master cylinder against the booster flange, I can feel the piston in the master cylinder depressing. If I installed it like that, I would have locked down brakes from the get go. The master cylinder likes about .100" from seating to the booster. I have ordered one of the booster pin gauges and it's obvious I will need to make an adjustment. Instead of trying to shorten the booster pin and get the correct radius back on it, I think I will probably have the "spud" machined down on it's non-concave side. I've read that there needs to be .020" clearance between the master cylinder piston seat and the booster rod. I would think that with today's CNC machining and precision, aftermarket parts manufacturers would have everything exact in dimensions. It's obvious the mismatch between my booster and master cylinder is either a manufacturing error or their blueprints are wrong to begin with. It seems like most of the time with reproduction parts, I have to "make" them fit or work correctly.
