Lost Power steering ... WTF??? - Page 2 - Team Camaro Tech
 6Likes
post #16 of 34 (permalink) Old Jun 11th, 19, 01:26 PM
Re: Lost Power steering ... WTF???
Originally Posted by Just 1 More View Post
Actually, No, it;s not making any noise. It did seem like it got hotter than I would have expected in the short amount of time i ran it.
I've run a quart of fluid through the gearbox.. not sure how much more I can do
I hope you are going to add a filter when you reinstall your pump. It will get anything the flush missed.
1959 El Camino project
1957 Buick Caballero project
dhutton is online now
post #17 of 34 (permalink) Old Jun 11th, 19, 01:30 PM Thread Starter
Frank
I saw the link to the one you posted, do they make one with AN fittings?
'68 Camaro 454, 4sp
Just 1 More is offline
post #18 of 34 (permalink) Old Jun 11th, 19, 02:05 PM
Yep. Here is one:
https://www.summitracing.com/parts/ati-925171
post #19 of 34 (permalink) Old Jun 11th, 19, 07:35 PM Thread Starter
Frank
Nice but.... OUCH!
'68 Camaro 454, 4sp
post #20 of 34 (permalink) Old Jun 11th, 19, 07:50 PM
Nice but.... OUCH!
Thatís why I posted the other one...
post #21 of 34 (permalink) Old Jun 12th, 19, 05:42 AM Thread Starter
Frank
Well,, you know i'm going to have to spend the $$ and get that one to go inline with my braid lines
'68 Camaro 454, 4sp
post #22 of 34 (permalink) Old Jun 12th, 19, 07:21 AM
Return side not the pressure side.
post #23 of 34 (permalink) Old Jun 12th, 19, 08:57 AM Thread Starter
Frank
Hate that i'm going to cut and splice but at least with the -6n fittings it should look somewhat ok in the line there somewhere
20190524_164050 by F G, on Flickr
20190524_163949 by F G, on Flickr
jimnecci likes this.
'68 Camaro 454, 4sp
post #24 of 34 (permalink) Old Jun 12th, 19, 05:46 PM
David Pozzi
davidpozzi's Avatar
You probably could have fixed it by removing the outlet fitting & flow control valve & run a magnet around. A small shaving or piece of hose will stick the valve open
davidpozzi is offline
post #25 of 34 (permalink) Old Jun 12th, 19, 07:18 PM
Beth
Originally Posted by Vega$69 View Post
Need to run fluid while turning stop to stop until fluid runs clear.
With the wheels off the ground
68 Camaro convertible, 6.0 LQ4 with LS3 heads, Vintage Air, 750 street demon carb, eddy perf rpm, GM hot cam, Hooker headers, 4L80e, 12 bolt, 3.55 gears
NashvilleCat is offline
post #26 of 34 (permalink) Old Jun 13th, 19, 05:43 AM
Chris
How about using AN fittings to connect the filter to the pump reservoir directly in some configuration that looks nice and then directly connect your return hose to the filter at the pump instead of cutting into your nice braided hose for an inline splice?
Just 1 More likes this.
'69 Z/28, Lemans Blue/White Stripes, DZ302, Tremec Magnum, 4.10, Procar Elite Seats,
Custom Upholstery, Dynatech headers, 17" VWW V45's, 235/45, 275/40, C5 Front Brakes
ctcz28 is offline
post #27 of 34 (permalink) Old Jun 13th, 19, 05:47 AM Thread Starter
Frank
I thought about that.. either off the pump or the gear box
'68 Camaro 454, 4sp
post #28 of 34 (permalink) Old Jun 13th, 19, 08:48 AM
What is that hose. Not sure it's what you should be using for powersteering.
1968 that started life and a 6 banger with a PG. Now it's a 350 with a TKO600, Moser 12 bolt, Speedtech LCA/UCA, ATS Tall Spindles, Hotchkis Springs, Forgeline ZX3P, C5 (Kore3) brakes with other cool stuff from Ron Davis, Vintage Air and soon to be Terminator EFI.
eville is offline
post #29 of 34 (permalink) Old Jun 13th, 19, 11:50 AM Thread Starter
Frank
What is the concern with the hose?
PTFE lined high performance hose with AN sizes AN8 and AN6 available and come in multiple options for Braid. Hot Rod fuel hose comes in Black, Blue, and Red nylon braiding as well as classic stainless steel. Very good chemical resistance supports even the toughest automotive fluids. Great for Gasoline, E85, Alcohol, Diesel, Transmission fluid ect.
'68 Camaro 454, 4sp
post #30 of 34 (permalink) Old Jun 13th, 19, 12:19 PM
David Pozzi
davidpozzi's Avatar
There are some AN -6 screen fuel filters that will work for PS Fluid. The hose type filters with barbed ends do not fit inside =6 AN hose. You would have to heat the hose to shove it in and it expands the braid too much to do that.
https://leepowersteering.com/product...p-to-6gpm-flow
