Lost Power steering ... WTF??? - Team Camaro Tech
 6Likes
post #1 of 34 (permalink) Old Jun 10th, 19, 06:49 AM Thread Starter
Frank
This is a brand new unit part of the Concept 1 serpentine system. I took it for a nice 80 mile run on Friday, started the car Saturday morning and no power steering .. . Opened the reservoir and it's full but no fluid movement. I figure i'll pull the lines, drain the system, crank the wheel left & right a few times with hoses off to push out more fluid, blow the lines out, refill, and try to bleed... Any thoughts? advice? Anyone know what pump this is? If it's available from Summit or Jegs or??
20190429_164856 by F G, on Flickr
'68 Camaro 454, 4sp
Just 1 More is offline
post #2 of 34 (permalink) Old Jun 10th, 19, 07:03 AM
Re: Lost Power steering ... WTF???
There is quite a bit of chatter on the pro touring forums about pump failures and the need for an inline power steering filter to prevent them.
1959 El Camino project
1957 Buick Caballero project
dhutton is offline
post #3 of 34 (permalink) Old Jun 10th, 19, 07:53 AM
69-Pace's Avatar
Don - Pardon my ignorance, my knowledge and understanding of power steering is limited to OEM set-ups, so can you take a moment and tell me what the issue is with these pumps and how a filter prevents the failure? Is it a contamination/over aeration issue? Or is the "filter" just a device to reduce flow/increase pressure?
Vega$69 likes this.
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #4 of 34 (permalink) Old Jun 10th, 19, 08:22 AM
Ed
Maybe you got a bad pump. Sometimes that happens.
ZEN357 is offline
post #5 of 34 (permalink) Old Jun 10th, 19, 09:17 AM
Frank, Because the unit is new I would talk with the supplier before doing anything
that might void the warranty.
my 67' build thread:
allanjs is offline
post #6 of 34 (permalink) Old Jun 10th, 19, 10:09 AM
Vega$69's Avatar
If you put a new LS style pump in and an old power steering box without flushing it completely until the fluid ran clear debris in the fluid may have ruined the PS pump.
The LS pump are vane type and more susceptible to contaminates then the OEM style pumps.
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #7 of 34 (permalink) Old Jun 10th, 19, 10:40 AM
Contamination. LS style pumps are easily damaged by debris as John noted above. Sounds like a new pump may have been connected to an old box...
This is one of David Pozzi’s topics so hopefully he will weigh in....
https://www.ebay.com/itm/New-Magnefi...0af63f32d788a7
dhutton is offline
post #8 of 34 (permalink) Old Jun 10th, 19, 11:10 AM Thread Starter
Frank
Yes,,, new pump, old box,,, damnitman.. I really thought I flushed the system pretty good
'68 Camaro 454, 4sp
post #9 of 34 (permalink) Old Jun 10th, 19, 05:08 PM
Vega$69's Avatar
What the fluid look like?
Vega$69 is offline
post #10 of 34 (permalink) Old Jun 10th, 19, 05:44 PM
69-Pace's Avatar
Thanks Don for the education.
69-Pace is offline
post #11 of 34 (permalink) Old Jun 10th, 19, 06:13 PM Thread Starter
Frank
Ugly... I obviously didn't flush as good as I thought.. or heck.. maybe I thought I did and didn't.. IDK... Either way,, it's phucked.
I talked to Ben at Concept 1 and he agreed to let me send it back and he'll go through it for me and get it back to me.. Great customer service.
'68 Camaro 454, 4sp
post #12 of 34 (permalink) Old Jun 10th, 19, 06:47 PM
69-Pace's Avatar
So basically he thinks he can rebuild it for you that's awesome.
69-Pace is offline
post #13 of 34 (permalink) Old Jun 10th, 19, 07:30 PM
Vega$69's Avatar
Is the pump making noise?
My whole understanding of old box new pump comes from been there done that. Haha
69-Pace and Just 1 More like this.
Vega$69 is offline
post #14 of 34 (permalink) Old Jun 11th, 19, 06:30 AM Thread Starter
Frank
Actually, No, it;s not making any noise. It did seem like it got hotter than I would have expected in the short amount of time i ran it.
I've run a quart of fluid through the gearbox.. not sure how much more I can do
'68 Camaro 454, 4sp
post #15 of 34 (permalink) Old Jun 11th, 19, 06:46 AM
Vega$69's Avatar
Need to run fluid while turning stop to stop until fluid runs clear.
69 Z28(Sold)
(SOLD)
Vega$69 is offline
