HELP!!! Power steering issues... continued - Team Camaro Tech
 6Likes
post #1 of 36 (permalink) Old Jun 17th, 19, 06:08 PM Thread Starter
Frank
Got the new pump, installed it, filled with fluid, fired up the car and still no power steering Pulled return line, fired it up and good fast flow.. reconnect, fill with fluid and again, no PS. Each time, I turned the wheel lock to lock several times trying to bleed the system of air.
Could it be the gear box? What and how do they act when something goes bad in them? I'm so freakin not happy right now
'68 Camaro 454, 4sp
Just 1 More is offline
post #2 of 36 (permalink) Old Jun 17th, 19, 08:06 PM
Tom Anderson
Re: HELP!!! Power steering issues... continued
When my gearbox was bad my car would jump when you turned it , very dangerous to drive but for your are you sure the belt is tight ? . Just throwing that out because a loose belt can do that . The belt needs to be tight
socal_tom is offline
post #3 of 36 (permalink) Old Jun 17th, 19, 08:15 PM
Vega$69's Avatar
Maybe the flow valve. Idk.
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #4 of 36 (permalink) Old Jun 17th, 19, 08:26 PM
Frank, You may have to turn lock to lock 30 or more times. Are you seeing a drop in the fluid level?
That would indicate air in the system.
my 67' build thread:
allanjs is offline
post #5 of 36 (permalink) Old Jun 18th, 19, 09:47 AM Thread Starter
Frank
Belt is tight
20190429_164856 by F G, on Flickr
'68 Camaro 454, 4sp
post #6 of 36 (permalink) Old Jun 18th, 19, 09:48 AM Thread Starter
Frank
Fluid dropped twice and I refilled, when it's full the fluid drops a little when turning to the left but comes back up and overflows when I turn right
'68 Camaro 454, 4sp
post #7 of 36 (permalink) Old Jun 18th, 19, 10:05 AM
Get the wheels off the ground and cycle the steering end to end multiple times without the engine running. That is the way to get out the air in my experience. Not good practice to run the pump before doing this imho....
1959 El Camino project
1957 Buick Caballero project
dhutton is online now
post #8 of 36 (permalink) Old Jun 18th, 19, 10:08 AM Thread Starter
Frank
Thought I was supposed to do it with it running... i'll try it your way and see what happens
'68 Camaro 454, 4sp
post #9 of 36 (permalink) Old Jun 18th, 19, 10:16 AM
I didn't realize you were running the motor. Don is correct. Wheels off the ground
and cycle from lock to lock numerous times with the reservoir cap off or loose so
the air can escape.
allanjs is offline
post #10 of 36 (permalink) Old Jun 18th, 19, 10:21 AM
Nope. You will hear the air escaping through the lines. Might have to let it sit several hours before doing it if it has been running since the fluid will be well aerated.
post #11 of 36 (permalink) Old Jun 18th, 19, 10:24 AM Thread Starter
Frank
the air can escape.
Thanks guys.. it's been sitting over night so I should be settled by now
'68 Camaro 454, 4sp
post #12 of 36 (permalink) Old Jun 30th, 19, 02:02 PM Thread Starter
Frank
Well... I'm pretty sure i burned up that pump by trying to bleed it while running. I jacked it up, turned lock to lock 50+ times, fired it up, no PS and the pump gets very hot very fast.
Anyone know the application for one of these pumps if I were to go to a parts store, what car would I look it up for? I think I read somewhere that one off a 1990 Celebrity would work, and the 1998-2002 Camaro and '97 Corvette also but they are different pressures and different size pulley shafts, one uses bushings and the other uses roller bearings???
I want to try a stock pump before I go burning up another one of these polished expensive ones
'68 Camaro 454, 4sp
post #13 of 36 (permalink) Old Jun 30th, 19, 04:29 PM
Ok let me ask a stupid question. Do you have the hoses on the box reversed?
post #14 of 36 (permalink) Old Jun 30th, 19, 04:37 PM
Brett
I have a brand new one, but it appears it is not the same. The one I have is a GM Type II remote reservoir I received with my serpentine system from CVF Racing. I chose to go with an attached reservoir so this one is a spare right now. It's the one on the left....
Brett.....
Just 1 More likes this.
Rockets Up In 2020!
Brettallen59 is offline
post #15 of 36 (permalink) Old Jun 30th, 19, 07:37 PM Thread Starter
Frank
I have no clue.. i've questioned this myself.. pressure side of pump to the port on the box closest to the engine.
'68 Camaro 454, 4sp
