Rear Brake Line - Team Camaro Tech
 5Likes
  • 1 Post By HawkX66
  • 2 Post By HawkX66
  • 1 Post By allanjs
  • 1 Post By cjs27410
post #1 of 8 (permalink) Old Jun 18th, 19, 08:19 AM Thread Starter
Apprentice
Chris
Rear Brake Line
Bought a 67 a several months ago. Did not like the way the brake line fit. This is the line from the steel tube to the splitter block mounted to the diff. Logan at Camaro Central suggested an aftermarket braided line that was longer. Problem solved.
Name:	brake line 2.jpg
ID:	227699   Click image for larger version
Name:	brake line 1.jpg
cjs27410 is offline
post #2 of 8 (permalink) Old Jun 18th, 19, 09:56 AM
Re: Rear Brake Line
Your first picture is not a factory fit. I'm glad you were able to fix it with a longer braided line.
yellow69RS likes this.
'69 SS396 X66 L34 08D M21 BS
460ci Gen VI 9.75:1 AED 950 carb
Semper Fi!
HawkX66 is offline
post #3 of 8 (permalink) Old Jun 18th, 19, 08:55 PM
Jeff
yellow69RS's Avatar
Re: Rear Brake Line
Since you mentioned it doesn't the factory steel line go in the top of that bracket? I think if it did the rubber line would be long enough. Just my .02
Jeff
yellow69RS is offline
post #4 of 8 (permalink) Old Jun 18th, 19, 09:18 PM
Re: Rear Brake Line
Jeff, The factory line goes in the bottom. His bracket is mounted in the wrong location.
It should be attached to the larger cross panel on the trunk floor rearward of where
it is now.
my 67' build thread:
allanjs is offline
post #5 of 8 (permalink) Old Jun 18th, 19, 10:21 PM
Re: Rear Brake Line
FWIW, my rear brake line position, 67.
I just used rubber replacement lines F&R
SoCal805 is offline
post #6 of 8 (permalink) Old Jun 19th, 19, 08:57 AM
Re: Rear Brake Line
Jeff
it is now.
His is mounted in the correct location and orientation. It looks like the flex line was just too short.
yellow69RS and ssrocket67 like this.
Semper Fi!
HawkX66 is offline
post #7 of 8 (permalink) Old Jun 19th, 19, 09:33 AM
Re: Rear Brake Line
Dave, You're correct. I was looking at some old pics of mine during tear down and just didn't see it correctly.
HawkX66 likes this.
allanjs is offline
post #8 of 8 (permalink) Old Jun 20th, 19, 10:15 AM Thread Starter
Apprentice
Chris
Re: Rear Brake Line
Thanks for the feedback. My car started out with 4 drum brakes. Front disc conversion and new lines all the way around in 2005.
HawkX66 likes this.
cjs27410 is offline
