Caltrac Bars - Team Camaro Tech
 1Likes
  • 1 Post By oldschoolchevy
post #1 of 6 (permalink) Old Jun 20th, 19, 12:05 PM Thread Starter
Ben
Caltrac Bars
anyone on here running Caltrac traction bars on a 67 with stock shock locations? i just ordered a set and i'm curious if the shock plates will work with non-staggered shocks
bhodgdon400 is offline
post #2 of 6 (permalink) Old Jun 20th, 19, 02:37 PM
Ray
Re: Caltrac Bars
I had a set on a '67 several years ago and all I can say is that I don't remember having an issue with them. I can honestly say that I don't remember the shock orientation. It did have the factory upper mounts and was a standard Camaro 12 bolt rear axle.
Not much help, I know.
Ray
Thanks,
Ray
'69 Z/28, born with 302, owned since 1982.
Rallye Green Z is offline
post #3 of 6 (permalink) Old Jun 20th, 19, 04:28 PM
Jeff
Re: Caltrac Barsw
Yes they will fit....when you order them you buy based on stock location.
Thanks,
Jeff
1968 Camaro
Chevy68 is offline
post #4 of 6 (permalink) Old Jun 21st, 19, 08:49 AM Thread Starter
Ben
Re: Caltrac Barsw
i ordered through Summit and there was not an indication or option for Shock location. i entered 67 camaro and the part number that came up said it fit 67-69 Camaro. that's why i ask. guess i'll wait and see. Summit is usually pretty good to work with so i'm sure if i have an issue they will take them back and replace with the right parts
post #5 of 6 (permalink) Old Jun 21st, 19, 07:10 PM
Re: Caltrac Bars
You should be fine.
The Caltrac spring plate is designed so that the rear shocks can be mounted in several configurations (staggered or non-staggared... and both options can be mounted to the inside or outside of the leaf springs). It all depends on how you position/install the Caltrac spring plates.
bhodgdon400 likes this.
oldschoolchevy is offline
post #6 of 6 (permalink) Old Jun 24th, 19, 05:12 AM Thread Starter
Ben
Re: Caltrac Bars
Originally Posted by oldschoolchevy View Post
You should be fine.
excellent, that's what i was hoping. thank you
