Idler Arm Bushing - Team Camaro Tech
post #1 of 3 (permalink) Old Jun 24th, 19, 06:17 PM Thread Starter
Dale
Idler Arm Bushing
I needed to drop my steering box and once I removed the castle nut and separated the idler arm a small little bushing covered in grease was still on the idler arm. When I removed it, I noticed it was split and open. So I am looking to replace just that piece. Problem is that I can't seem to find just that. Seems that I need to buy the whole idler arm setup to get just this little bushing. Does anyone know where to find or get one?
67 Camaro
Wigman87 is offline
post #2 of 3 (permalink) Old Jun 24th, 19, 07:14 PM
Re: Idler Arm Bushing
That's just a thick felt washer to help keep gunk out of the joint. It's not a necessity.
Used to be able to buy felt battery post washers. You might find those. It would probably
fit and function the same.
Edit: Some of the idler arms used a sponge type material.
my 67' build thread:
allanjs is offline
post #3 of 3 (permalink) Old Jun 24th, 19, 09:08 PM
David Pozzi
davidpozzi's Avatar
A slice of rubber hose will work
davidpozzi is offline
