rear brake line 1968 camaro - Team Camaro Tech
post #1 of 5 (permalink) Old Jun 24th, 19, 10:54 PM Thread Starter
Apprentice
rick
drivers rear brake line broke,i replaced it and when bleed it first 3 times went ok but the when i had my wife push down on the brake pedal it was hard at very top,i unhooked the line at the block my center of rearend and had her push brake pedal again and no brake fluid coming out of the block,any ideals what the problem is??
camaroz/28 is offline
post #2 of 5 (permalink) Old Jun 24th, 19, 11:13 PM
Pat
Re: rear brake line 1968 camaro
If you disconnected the flex hose from the junction block on the diff and you canít get fluid out, Iíd bet the flex hose is bad. They deteriorate and collapse inside, and cause a blockage.
Been there...done that!
Also, if the rear one is bad, itís time to replace the front ones too.
Pat - 68 Camaro Coupe -
patman2 is offline
post #3 of 5 (permalink) Old Jun 25th, 19, 11:22 AM
^^^yep
and if the flare fitting from hard brake line is frozen to rubber line these wrenches work when a flare wrench won't.
This is the same Snap-On tool that costs stupid $ for way less
https://www.ebay.com/p/AGS-Flexforce...d=172814096509
SoCal805 is offline
post #4 of 5 (permalink) Old Jun 25th, 19, 06:47 PM Thread Starter
Apprentice
rick
oo.
No i only unhooked the hard line from the metal connector at rearend ,a mechanic told me that when my old line broke that the proportion valve closed off fluid to rear and to just let a little brake fluid out of one of the front brakes and this would let the ball go back to center allowing fluid to go to rear brakes but i tried this 3 times with no luck smd there is also no reset on either end of the proportion valve
post #5 of 5 (permalink) Old Jun 25th, 19, 06:47 PM Thread Starter
Apprentice
rick
