Master Brake Cylinder - Team Camaro Tech
post #1 of 8 (permalink) Old Jul 2nd, 19, 06:27 AM Thread Starter
Bruce
Converted to rear disc brakes on a 69. The MBC set up is a 9" Chrome set up and the MBC has the same size lines, front and back and reservoir holes are the same size. A local shop said this would work, I have heard otherwise. What is the right answer?
The Camaro Guy is offline
post #2 of 8 (permalink) Old Jul 2nd, 19, 06:43 AM Thread Starter
Bruce
Re: Master Brake Cylinder
Correction, the line is larger in the rear of the MBC, 9/16 fitting, the front 1/2
post #3 of 8 (permalink) Old Jul 2nd, 19, 05:53 PM Thread Starter
Bruce
one more try
post #4 of 8 (permalink) Old Jul 2nd, 19, 06:40 PM
Red face Re: Master Brake Cylinder
With my limited knowledge, If you use a disc/disc proportioning valve you should be ok.
TJS69 is offline
post #5 of 8 (permalink) Old Jul 2nd, 19, 06:51 PM
Andrew
Andrew69's Avatar
There is a specific master cylinder for disc/disc applications, I am unsure they differ. I don't think the size of the connector makes any difference.
Skunk Works
Some photos:
Member # 159
Andrew69 is offline
post #6 of 8 (permalink) Old Jul 2nd, 19, 08:03 PM
Beth
Read Al's writeup on installing rear discs :
https://www.camaros.net/forums/16-br...-pictures.html
68 Camaro convertible, 6.0 LQ4 with LS3 heads, Vintage Air, 750 street demon carb, eddy perf rpm, GM hot cam, Hooker headers, 4L80e, 12 bolt, 3.55 gears
NashvilleCat is offline
post #7 of 8 (permalink) Old Jul 6th, 19, 05:46 AM Thread Starter
Bruce
Right Stuff said all I had to change was the distribution block. MC is fine. FYI
post #8 of 8 (permalink) Old Jul 6th, 19, 06:04 AM
Andrew
Andrew69's Avatar
Which distribution block do they recommend?
Skunk Works
Some photos:
Member # 159
Andrew69 is offline
