Bleeding Rear Brakes - Team Camaro Tech
 3Likes
  • 1 Post By SoCal805
  • 2 Post By SoCal805
post #1 of 15 (permalink) Old Jul 4th, 19, 09:19 AM Thread Starter
I put on some Speedbleeders and when I bleed my brakes, only the front brakes are bleeding but the rears brakes are not?
johnv805 is offline
post #2 of 15 (permalink) Old Jul 4th, 19, 10:28 AM
Re: Bleeding Rear Brakes
The first thing that comes to mind is the rear flex hose being collapsed internally.
You should be starting at the right rear wheel, then left rear, right front, left front
bleeding one wheel at a time. Is this a complete new brake system or? More info is needed.
my 67' build thread:
allanjs is offline
post #3 of 15 (permalink) Old Jul 4th, 19, 10:36 AM
I find gravity bleeding works very well. Try removing the speed bleeders entirely and let the brakes gravity bleed. Keep the MC fluid topped off during gravity bleed
as noted your soft line near the rear end may be restricted or collapsed if it is old. Good time to replace if it is unknown age...along with the fronts also
rp930 likes this.
SoCal805 is offline
post #4 of 15 (permalink) Old Jul 4th, 19, 11:23 AM
allanjs, I am currently replacing my 51 year-old flex hoses, master and two wheel cylinders and will soon be bleeding my '68 Firebird. (I'm going to use try a vacuum bleeder method.) The 1968 Pontiac Service Manual recommends left front, right front, left rear, right rear order. Is the sequence you mention a more current recommendation? I'm assuming the same brake hydraulics Chevy/Pontiac in '68.
68 400HO Conv.
68Conv400HO is offline
post #5 of 15 (permalink) Old Jul 4th, 19, 11:42 AM
Unless there is something unique about the 68 Bird.....every car/year/model I have bleed brakes on is starting with wheel the furthest away from MC. RR, LR, RF, LF...
Gravity bleed I do rears first (both same time) then fronts
rp930 and tuxedoblack like this.
SoCal805 is offline
post #6 of 15 (permalink) Old Jul 4th, 19, 11:53 AM
Jim, The sequence I described has been the recommended method for decades. Bleed the longest
line first and then progressively shorter lines. That was my training as a certified brake, suspension,
and alignment tech in the early 70's and have always used this method with success. I have used a
pressure bleeder but never a vacuum bleeder. Just never had the need.
allanjs is offline
post #7 of 15 (permalink) Old Jul 4th, 19, 01:04 PM
Thanks SoCal and Al. I just researched the firstgenfirebird.org and found the same question; Pontiac Service Manual verses usual practice. It still seems a mystery. One comment mentioned master cylinder bleeders but only some Birds (including mine) and Tempests got those. Since front and rear are separate hydraulics anyway it may not be that critical. I'll probably bleed the front MC and then the front as I am currently doing the parts changes there first. Then do the rear parts and then bleed its system. Finally, I'll do a second bleeding using your order when all else is done.
68 400HO Conv.
post #8 of 15 (permalink) Old Jul 4th, 19, 01:12 PM
keith
X-77 keith's Avatar
Bench bleed the master cylinder first. Always. I have always used the farthest and worked towards the shortest line. Never had a problem. The vacuum method is no better than having someone pump the brakes in my opinion. I have one. Tried it twice, now its just in the corner of the shop. Gravity bleeding is always a good start. Like mentioned don't let the MC go dry.
X-77 keith
X-77 keith is offline
post #9 of 15 (permalink) Old Jul 4th, 19, 01:14 PM
Took this from another forum. Best explanation I have seen from one of the guys there.
Look at it as two separate brake systems, front and rear. There are two separate pistons in the master cylinder, the only thing tying them together is a spring and brake fluid.
Which ever port on the master cylinder is closest to the brake pedal is the system that you bleed first. Starting with the farthest caliper in that end of the system.
So in the case of the DSE setup, the front port is rear brakes and the rear port is front brakes. You would bleed the front brakes first starting with the passenger side caliper. The reason being is that the front piston won't really stroke all the way until the rear piston is bled. It just makes the job go faster, you can certainly do it "wrong" and be successful, I have.
1959 El Camino project
1957 Buick Caballero project
dhutton is offline
post #10 of 15 (permalink) Old Jul 4th, 19, 06:02 PM
Brett
Don, in the picture, which are you calling "Front Port" and which are you calling "Rear Port". If I'm looking at the diagram, to me, the one closest to the brake pedal is the "Rear Port", which on our cars is the rear brakes. Am I seeing it wrong?
Brett.....
Rockets Up In 2020!
Brettallen59 is offline
post #11 of 15 (permalink) Old Jul 4th, 19, 06:11 PM
keith
X-77 keith's Avatar
Your right Brett. Primary would be front brakes.
X-77 keith
post #12 of 15 (permalink) Old Jul 4th, 19, 06:25 PM
Brett.....
He is referring to the port closest to the front of the car as the front port.
He is saying the port closest to the rear of the car should be bled first regardless of which brakes it is connected to....
dhutton is offline
post #13 of 15 (permalink) Old Jul 13th, 19, 01:35 PM Thread Starter
Yes, I did start in the proper order: right rear, left rear, right front, then left front. Only the fronts bleed. I did a front disc brake conversion in 2005 so only the front brake fluid hoses were change during that year.
johnv805 is offline
post #14 of 15 (permalink) Old Nov 24th, 19, 01:53 PM Thread Starter
The real flex hose was bad and so I changed it and now the rear brakes can bleed. Thanks everyone.
johnv805 is offline
post #15 of 15 (permalink) Old Nov 24th, 19, 01:59 PM
Thanks for following up. That can help anyone in the future. I assume you meant "rear" not real.
allanjs is offline
