Steering column to rag joint adjustment? - Team Camaro Tech
 1Likes
  • 1 Post By ilikeike
post #1 of 7 (permalink) Old Jul 10th, 19, 05:32 AM Thread Starter
Probationer
I installed a new manual steering box in my 68. There’s a gap between the rag joint and the steering column. There seems to be an adjustable portion of the steering column. Will the steering column telescope out a little bit and if so, how do I make that adjustment? Thanks in advance
RBird is offline
post #2 of 7 (permalink) Old Jul 10th, 19, 05:35 AM Thread Starter
Probationer
Photo.
RBird is offline
post #3 of 7 (permalink) Old Jul 10th, 19, 07:00 AM
Ray
Re: Steering column to rag joint adjustment?
I'm interested to see anyone respond here. The picture looks like mine did before I changed to power two years ago. I wish the column had an adjustment because the stock '67 2 1/2 turn lock to lock gear box leaves no room.
The AIM dose not say anything about for and aft adjustment only top and bottom angles.
'68 rs/SS 350 M-21 posi
numbers matching
rgwiz is offline
post #4 of 7 (permalink) Old Jul 10th, 19, 07:12 AM
Darin
ilikeike's Avatar
It's been 3 or 4 years since I put my column in, but I thought it was only adjustable in the slots where it bolts under the dash ?
rgwiz likes this.
1968 Butternut Coupe,
421" Dart SHP block
TKO 600 RR
Dutchman 9" w/3.70
Global West arms
Budnik wheels
ilikeike is online now
post #5 of 7 (permalink) Old Aug 4th, 19, 10:57 AM
Larry
Correct. Plus, the firewall seal clamp also needs to be loosened. I believe that will do the trick.
Current Project:
69 Z/28 Resto-Mod
Next In Line:
83 Z28 Restoration
69-er is offline
post #6 of 7 (permalink) Old Aug 4th, 19, 05:00 PM
OK, my steering box is very sloppy, going to adjust it one day...maybe.
BUT, I will ask what/who's did you go with and how is it ?
68 Camaro~LSx ~all motor
post #7 of 7 (permalink) Old Aug 4th, 19, 06:25 PM
Vega$69's Avatar
Often when pulling the column or steering box the column is partially collapsed when rag joint is pried away from the steering box.
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
