mono leaf install image - Team Camaro Tech
post #1 of 7 (permalink) Old Oct 9th, 19, 10:32 AM Thread Starter
Apprentice
Getting prepared to start putting the 67 back together. It's been so long I don't remember how things went together with mono leaf, spring purches, etc to the rearend. Anyone have an image they would share? Also any advice or suggestions would be appreciated. TIA Pete
67 327 Base Convertible
PeteMag is offline
post #2 of 7 (permalink) Old Oct 9th, 19, 11:53 AM
Re: mono leaf install image
Good time to add sub frame connectors if installing leaf springs......unless you are doing a complete "stock" assembly
SoCal805 is offline
post #3 of 7 (permalink) Old Oct 9th, 19, 12:43 PM
Randy
Here is a pic
Name:	Spring Purch Lt.jpg
57s67RS/SS is online now
post #4 of 7 (permalink) Old Oct 9th, 19, 01:19 PM Thread Starter
Apprentice
I'll have to research that out. Not familiar with those. And of course what I need is for a convertible so.....
PeteMag is offline
post #5 of 7 (permalink) Old Oct 9th, 19, 01:21 PM Thread Starter
Apprentice
Originally Posted by 57s67RS/SS View Post
Here is a pic
THANK YOU that's exactly what I needed. I'm a visual person.
PeteMag is offline
post #6 of 7 (permalink) Old Oct 9th, 19, 02:13 PM
All 1st gen Camaro are "unibody" cars (not full frame cars) with a front & rear "clip". Sub-Frame connectors join the front & rear clips making the car flex les and handle better. Perhaps even more beneficial to a convertible
Several companies make them. IMHO the "Summit" brand is fine and likely the least expensive (ones I installed).
The reason I noted this is they use the same 3 bolts to mount to the rear frame where the leaf spring bolts to
SoCal805 is offline
post #7 of 7 (permalink) Old Oct 9th, 19, 02:56 PM
Darin
ilikeike's Avatar
Order or download and print the factory assembly manual. You can put the entire car together using this.
I did.
https://drive.google.com/file/d/0B0l...usp=drive_open
I still reference it regularly.
1968 Butternut Coupe,
421" Dart SHP block
TKO 600 RR
Dutchman 9" w/3.70
Global West arms
Budnik wheels
ilikeike is offline
