Steering Box Port Question - Team Camaro Tech
 8Likes
  • 2 Post By dhutton
  • 2 Post By 69Z28
  • 1 Post By dhutton
  • 1 Post By Brettallen59
  • 1 Post By 57vette
post #1 of 15 (permalink) Old Jan 1st, 20, 03:34 PM Thread Starter
Brett
I am attempting to replace my steering box. The old one has the ferrules inside the ports. The rebuilt one I purchased from Rock Auto does not. I feel pretty sure I must have these or it will leak. Can I buy them? Can I remove the ones in the old unit? Or did they cut them out and I need to send it back!?
Thanks,
Brett.... Oh, Happy New Year!!!!
The first pic is the old unit, bottom is the rebuilt, new unit.....
Rockets Up In 2020!
Brettallen59 is offline
post #2 of 15 (permalink) Old Jan 1st, 20, 03:43 PM
Re: Steering Box Port Question
Far from an expert but my guess is top one is flare and the bottom one is o-ring. Not positive though.
69Z28 and yellow69RS like this.
1959 El Camino project
1957 Buick Caballero project
dhutton is offline
post #3 of 15 (permalink) Old Jan 1st, 20, 03:48 PM Thread Starter
Brett
Don,
They did send o-rings, but they look too small. I just can't see them sealing. I guess I can try it. My hose fittings are still flare.
Brett....
Rockets Up In 2020!
post #4 of 15 (permalink) Old Jan 1st, 20, 04:01 PM
Originally Posted by Brettallen59 View Post
Don,
Brett....
The hose fittings are different for o-ring style. That is not a direct replacement steering box. You can probably buy adaptors from o-ring to flare.
dhutton is offline
post #5 of 15 (permalink) Old Jan 1st, 20, 04:05 PM
Gary
69Z28's Avatar
I can't remember the guy that was doing the nascar boxes. but someone said give him a call. I told him WHAT I was installing and what hoses I was using, and he sent me two flared pieces you just tap in the openings to seat flared factory style hoses. It's been since 2000 when I added power steering to my Camaro, and IIRC, I used a box from a 1980 WS6 Trans AM and haven't had any issues. Might be what you need.
dhutton and yellow69RS like this.
06A 1969 Camaro Z28 711 69 B Black Stripes Console w/tach and gauges
69Z28 is offline
post #6 of 15 (permalink) Old Jan 1st, 20, 04:11 PM
Something like this is what I think you need:
https://www.ebay.com/itm/CPP-605-Pow...kAAOSwRPhbiHpr
Make sure you have room for the added height.
dhutton is offline
post #7 of 15 (permalink) Old Jan 1st, 20, 04:31 PM
Gary
69Z28's Avatar
Been seeing the ebay adapters a lot lately. Looks like the factory OEM style hoses will work with those.
I used these, see below.
69Z28 is offline
post #8 of 15 (permalink) Old Jan 1st, 20, 04:52 PM
I think maybe those might work too but Iím not sure how they seal the o-ring port. Maybe just pressure on the sealing surfaces?
dhutton is offline
post #9 of 15 (permalink) Old Jan 1st, 20, 05:16 PM
Gary
69Z28's Avatar
I never thought to ask that question. I just trusted what the guy, I'm thinking Lee Manufaturing or Power Steering something like that that does the NASCAR boxes sent me. He just said tap them in, and you're good. Never looked back. I went out to look for leaks just a bit ago, and nice and clean. May be worth calling...to be sure??!!
69Z28 is offline
post #10 of 15 (permalink) Old Jan 1st, 20, 05:27 PM Thread Starter
Brett
Well yes, I have some of those inverted flare o-ring adapters here. I put the o-rings in they sent, but you are right, I need to do more than what I did. I put the whole thing together, but my steering column is apart right now and it got late. I'll see if it leaks and if it doesn't i'll leave it, but I doubt it's good. I think those brass ferules that are in the old one are just tapped in also. I could try to pop them out and see what it looks like underneath.
Thanks guys!
Brett.....
Rockets Up In 2020!
post #11 of 15 (permalink) Old Jan 1st, 20, 05:37 PM
The ones I posted might also change the threads from metric to imperial which Iím pretty sure you donít want to do.
69Z28 likes this.
dhutton is offline
post #12 of 15 (permalink) Old Jan 1st, 20, 05:38 PM
Gary
69Z28's Avatar
I found my old post if this can help here, or others going this route. 1980 WS6 T/A (metric lines). I think 1980 was the first year for metric fittings. After a little research I contacted Lee Manufacturing Co.-toll free 888-698-6697 and they sent me the seats/inserts- #40620 Pressure Seat $3.85 and #40630 Return Seat $3.85. Easy installation. The early hoses will screw right into the metric power unit perfectly. Found this link just for some info and chatter.
https://www.chevytalk.org/fusionbb/s...hp?tid/106481/
69Z28 is offline
post #13 of 15 (permalink) Old Jan 1st, 20, 05:43 PM Thread Starter
Brett
Thanks Gary. I'm gonna call.
Man! they got a bunch of fittings and flares and rag joints on their Lee website! Go to Lee Website
BTW, did anyone notice that my old box has a titty sticking out the end of the input shaft? The new one does not have it. ???
Brett...
69Z28 likes this.
Rockets Up In 2020!
post #14 of 15 (permalink) Old Jan 2nd, 20, 03:11 PM
Brett...
Maybe this is what you need?
I did the JGC steering box and its metric (1996) you insert these and then you can use your OEM-style 1969 hoses (non metric). I did this 3 years ago, dry as a bone. All these (newer) Saginaw boxes are pretty much the same.
69Z28 likes this.
'69 LeMans Blue Coupe, White Interior, 030" over 454, Super T10 4-Speed, Holley 4150, Pertronix Ignition
CompCams XS274S, 781 Oval Port Heads, PYPES Full 3" SS Exhaust, Hooker Comp Headers, Wilwood Calipers/MC
JGC Steering Box, Helix Uppers/Lowers, ProForged BJs, SpeedHut Gauges, MOMO Steering Wheel, Budnik 17" Wheels
57vette is offline
post #15 of 15 (permalink) Old Jan 2nd, 20, 04:35 PM Thread Starter
Brett
Yes, I ordered some from the Lee website.
Brett....
69Z28 likes this.
Rockets Up In 2020!
