Opinions on disc conversion and suspension - Team Camaro Tech
post #1 of 15 (permalink) Old Jan 6th, 20, 09:07 PM Thread Starter
Apprentice
I’m new to Camaro’s but just picked up a 67 that’s currently all stock unrestored but in decent shape. It’s all drums so I am at minimum going to upgrade front to disc but honestly it seems like for not much more money I could just go with a complete 4 wheel disc conversion. I’d like opinions on the best complete kit for the money and would prefer not to piece together things. I am also going to upgrade the suspension but I am wondering if it’s worth it to drop a couple grand on something like the complete kit that Ricks sells that includes a new steering box or the Hotchkis kit or should I just throw on some coilovers and new leafs and shocks. Basically how much better can I make it handle for around $2k. My car has manual steering so I thought the Ricks kit that includes a new power steering box seemed like a good deal unless it’s just not quality. Anyway thanks in advance for your help and I’ve already learned a ton from reading the forums.
Tdog is offline
post #2 of 15 (permalink) Old Jan 6th, 20, 09:53 PM
Beth
Re: Opinions on disc conversion and suspension
Just did a 67 Chevelle ; here's what I did:
All new Moog rubber bushings on upper and lower control arms
1" drop BMR lowering springs ($110 front)
Replaced upper and lower ball joints (you could install a longer upper ball joint)
1-1/4" addco front sway bar - for a Camaro, use 1-1/8" ($120)
You don't need a rear sway bar on a 67 -69 because of leaf spring suspension
KYB monotube shocks ($160 for 4)
1998 Grand Cherokee steering box from RockAuto ($140)
These mods are cheap and make a huge difference
68 Camaro convertible, 6.0 LQ4 with LS3 heads, Vintage Air, 750 street demon carb, eddy perf rpm, GM hot cam, Hooker headers, 4L80e, 12 bolt, 3.55 gears
NashvilleCat is offline
post #3 of 15 (permalink) Old Jan 6th, 20, 09:53 PM
Welcome to TC. Front disc is a great upgrade. Rightstuff Detailing has good complete kits.
To me rear disc is not worth the cost. You can upgrade the front suspension quite reasonably
without buying someone's full "kit". New front springs (possibly variable rate like Ridtech) will
make a good improvement. A good steering box and larger swaybar make a big improvement.
Here's a link to a thread on using the Jeep Grand Cherokee box and other info.
https://www.camaros.net/forums/16-br...ering-box.html
my 67' build thread:
allanjs is offline
post #4 of 15 (permalink) Old Jan 6th, 20, 09:59 PM
Beth
Forgot to mention brakes. If you are keeping 15" wheels, LS1 brakes won't fit.
You will need 17" wheels for the 12" rotors
BRP Hotrods has the kit , you can use your drum brake spindles to mount the brakes.
You can buy the calipers, rotors and rear backing plates for a 1998-2002 Camaro and install them on your car. The backing plates can be found in junkyards or ebay.
BRP Hot Rods: Brake Kit: 12" F-Body
See the "sticky" at the top of this thread; Al (BPOS) has excellent directions on how to install the rear brakes
post #5 of 15 (permalink) Old Jan 7th, 20, 08:40 AM
You can use a 15 inch steel wheel with a 12 inch rotor as that is how Caprice Cop cars were equipped. Those heavy duty steel wheels are vented (lots of round holes not rally wheels) so you can not run hub caps and look stock; you would need a full wheel cover.
Another option is to use the 2 inch wide by 11 inch in diameter rear drums off of a full size B-body car (the lighter A, F, and X-body cars used a smaller 9" drum). It also bolts up to your existing rear axle flange and retains the stock emergency brake cable, while increasing your stopping power. Unless you are going to road race the car you couldn't tell the difference in performance between the larger drum and the rear disc. MP sells them for $500 complete with backing plates ready to install: or you can pull them from the bone yard. Just be sure it is the older 1965-'79 body style as in 1979 GM went metric with five on five (127 mm actually) with M12-1.5 metric studs.
Big Dave
Larger Dave is offline
post #6 of 15 (permalink) Old Jan 28th, 20, 06:57 AM Thread Starter
Apprentice
This is great info and I believe I'm going to start with this set up. Can you point me in the right direction to get the longer ball joints? Thanks for the help
Tdog is offline
post #7 of 15 (permalink) Old Jan 28th, 20, 07:44 AM
Frank
https://proforged.autocaredata.com/items/101-10016
'68 Camaro 454, 4sp
Just 1 More is offline
post #8 of 15 (permalink) Old Jan 28th, 20, 07:45 AM
Frank
I went with all Pro-Forged replacement parts over Moog
'68 Camaro 454, 4sp
post #9 of 15 (permalink) Old Jan 29th, 20, 05:50 PM
ME4NSTRK69's Avatar
I recently did Moog steering rebuild kit from Summit, upper lower control arms from classic performance, new moog stock springs, fast ratio steering box from 396.com and a new 1 1/8th sway bar from DR classics
some years back I did front discs and energy suspension poly body bushings and competition engineering adjustable drag shocks. all of it made a huge difference. Very happy so far
I would like to do 4 wheel discs one day though.
1969 Camaro 350 200r4 342 Posi
1987 WE4 Turbo Regal E85
2003 Sierra Stepside RCSB Belltech dropped
MY BUILD THREAD:
ME4NSTRK69 is offline
post #10 of 15 (permalink) Old Jan 29th, 20, 06:53 PM
scblucam's Avatar
I used the 4 wheel manual kit from Stainless Steel Brakes. If I recall sourced from Jeg's. I'm happy with it. Don't put many miles on it but no problems
68 302 M20 - 85 IROC Z
scblucam is online now
post #11 of 15 (permalink) Old Jan 30th, 20, 06:45 AM
Kevin
KevinW's Avatar
Interesting thread! I have a similar setup, but my 4-drum systems includes the 14" drum ONLY original wheels. Is there any front disc system in which the calipers are SMALLER then the GM originals so that I can retain the current 14x6 rims?
Kevin
KevinW is offline
post #12 of 15 (permalink) Old Jan 30th, 20, 07:23 AM
Rick
Kevin,
You can use original style disc brake (front) parts on your 69 with 14 wheels. I have them on mine.
69 COPO clone, 461" BBC 11.25:1 Compression
840 Rec Heads (2.25/1.88) AED 850 HO carb
Orig Exhaust Manifolds
Straub (Clay Smith) cam, 288/300 .600/.569 109.
TH400, 3500 stall, 4.11 12 bolt posi
rp930 is offline
post #13 of 15 (permalink) Old Jan 30th, 20, 12:24 PM
Lyle
Right Stuff sells kits that work with the unmodified stock drum brake spindle and 14" non-disc brake wheels.
https://www.getdiscbrakes.com/afxwk14
thebat is offline
post #14 of 15 (permalink) Old Jan 30th, 20, 03:10 PM
Kevin
KevinW's Avatar
Very interesting! Since I already have a power disc master, for $400 I can get discs pretty easily with that kit. I can keep my current rims, just need to find/fab a dust shield. Thanks!
Kevin
KevinW is offline
post #15 of 15 (permalink) Old Jan 30th, 20, 07:03 PM
Kevin, Before you order that kit I would recommend you verify it uses easily obtainable
brake pads. There may be a possibility it requires something non-standard. Just a thought.
allanjs is offline
