power steering pump alignment - Team Camaro Tech
 5Likes
  • 1 Post By stevo camaro
  • 2 Post By SoCal805
  • 1 Post By jcor12
  • 1 Post By ilikeike
post #1 of 6 (permalink) Old Jan 10th, 20, 05:37 PM Thread Starter
Joe
I installed the March serpentine pulley/bracket kit on 350.* The power steering pump is not square to the block, causing misalignment with the crank pulley (picture).* To align, the outboard side of the pump needs to move back.* I can't put washers on inboard side because that would push pump further away from block (and therefore further out of line with crank pulley). Washers on outboard side make it worse.**
Any thoughts on how to draw the pump back to align and square it?
PS:* I know others have had alignment problems with this system but I used a similar set on the chevelle without issue.
Sent from my SM-G930T using Tapatalk
1967 Camaro RS 350, muncie
1970 Chevelle 454, 200 4r
jcor12 is offline
post #2 of 6 (permalink) Old Feb 1st, 20, 10:27 AM
stevo camaro's Avatar
Re: power steering pump alignment
Well Joe, looks like 143 people have read your question without a response. It's hard tell what the solution would be without standing there looking at it. Maybe something needs to be heated and bent to get the pump closer to the block? Hard to tell without seeing the back of the pump and motor.
Yeah, those serpentines are less forgiving on alignment than a belt, as you know.
jcor12 likes this.
67 RS 327, 4-speed, posi, done.
67 Modified, 454, TH-400, posi, under construction.
67 SS 396, 4-speed, basket case.
72 RS, sitting, partially done.
55 210 post, 2 door, 327 4-speed runs good.
55 2 door post, gasser project
69 Cadillac ElDorado
69 4x4 suburban
59 ElCamino
Some mornings, it's just not worth chewing thru the leather straps"
stevo camaro is offline
post #3 of 6 (permalink) Old Feb 1st, 20, 12:18 PM
Brandon
Can't you put a washer between the pump and the serp backet on the outboard side to push the pump back?
Brandon J. licence 1NASTY67
Nantooch is offline
post #4 of 6 (permalink) Old Feb 1st, 20, 12:22 PM
^^^^this or grind some off the engine side of the bracket where it bolts to block/head to bring the bracket back towards engine?
Nantooch and jcor12 like this.
SoCal805 is offline
post #5 of 6 (permalink) Old Feb 14th, 20, 01:18 PM Thread Starter
Joe
Thanks for replies...I ended up putting a washer between the bracket and pump and yes it did push it back just enough.
When I first thought of this, I assumed the pump would just push out on the bracket but that did not happen.
Nantooch likes this.
jcor12 is offline
post #6 of 6 (permalink) Old Feb 14th, 20, 03:22 PM
Darin
ilikeike's Avatar
I forgot to post a picture of mine, I was having technical difficultly with my Team Camaro account a couple weeks ago.
Anyway, I added a washer just like you did.
jcor12 likes this.
1968 Butternut Coupe,
421" Dart SHP block
TKO 600 RR
Dutchman 9" w/3.70
Global West arms
Budnik wheels
ilikeike is offline
