master cylinder info - Team Camaro Tech
post #1 of 8 (permalink) Old Jan 12th, 20, 04:41 PM Thread Starter
Steven
stamatisg1977's Avatar
im looking to get a wilwood master cylinder and to get rid of the old style with the booster
what size bore is recommended for 4 wheel disc with no booster?
lookin to clean up the engine bay a little more
69 Frost Green Camaro
LS3 with TSP stage 3 cam
Tremec TKO 600
Ridetech rear 4-Link
Follow my journey here:
stamatisg1977 is offline
post #2 of 8 (permalink) Old Jan 12th, 20, 07:31 PM
Darin
ilikeike's Avatar
I run a 7/8” for my manual discs.
A 15/16” will be a little less peddle travel and a little more effort.
You can call wilwood with your caliper specs and they could tell which would work best.
1968 Butternut Coupe,
421" Dart SHP block
TKO 600 RR
Dutchman 9" w/3.70
Global West arms
Budnik wheels
ilikeike is offline
post #3 of 8 (permalink) Old Jan 12th, 20, 07:46 PM
Re: master cylinder info
Some useful data here.
1959 El Camino project
1957 Buick Caballero project
dhutton is offline
post #4 of 8 (permalink) Old Jan 12th, 20, 08:33 PM Thread Starter
Steven
Were camaros 4:1 ?
Tremec TKO 600
post #5 of 8 (permalink) Old Jan 13th, 20, 06:08 AM
Originally Posted by stamatisg1977 View Post
Were camaros 4:1 ?
For a first gen the power brake pedal ratio is 3.5:1. The attachment point for manual brakes gives a 6:1 pedal ratio.
dhutton is offline
post #6 of 8 (permalink) Old Jan 13th, 20, 09:51 AM Thread Starter
Steven
My brake lines are small probably 1/8”. They are the speedtech lines for my subframe. And im probably gonna upgrade to c5!brakes up front and i have right stuff calipers in rear.
So with the smaller lines the line pressure will probably be automatically hight ( thinking of how a powerwasher works) and the front brakes may need more volume over stock. So probably a1” bore would be a good choice?
Tremec TKO 600
post #7 of 8 (permalink) Old Jan 13th, 20, 10:37 AM
Simon
I would recommend you speak to Tobin from Kore, he was very helpful in assisting me with parts as well as info for my C6 & LS1 rear setup.
KORE3 Industries LLC: On and Off-Road Performance Automotive Components
slazisme is offline
post #8 of 8 (permalink) Old Jan 13th, 20, 10:38 AM
I don’t think this is the case. Brake line diameter plays no significant role in brake pressure as far as I know.
dhutton is offline
