Leaf Spring/Shock question - Team Camaro Tech
 2Likes
  • 1 Post By Larger Dave
  • 1 Post By allanjs
post #1 of 10 (permalink) Old Feb 2nd, 20, 07:20 PM Thread Starter
I am installing a DSE 3" leaf spring drop kit https://www.detroitspeed.com/rear-su...p-041601-group. I have a '68 12 bolt that had multileafs in my 67 so I assumed that the brackets for the 68-69 multi leaf shocks would work. Not so - the shock that would mount behind the axle (driver's side) does not reach the mount.
New assumption - The '67 - having non-staggared shocks - cannot have the shocks mounted staggered and required both shocks in front of the axle. Confirmations?
I am ordering these brackets (https://www.detroitspeed.com/rear-su...-040302l-group) to use the Koni shocks that came with the kit and mount them in front of the axle.
So any thoughts out there? Will these non-staggered shock mounts work?
Thanks!
AZ_Bill is offline
post #2 of 10 (permalink) Old Feb 2nd, 20, 07:48 PM
Brett
Re: Leaf Spring/Shock question
How close does it get? I purchased 1-1/2" DSE drop springs and my shock was close to not fitting but was able to get it on with a little persuasion (Drivers side, Staggered, multi-leaf)
Brett....
Rockets Up In 2020!
Brettallen59 is offline
post #3 of 10 (permalink) Old Feb 2nd, 20, 09:20 PM
Jeff
yellow69RS's Avatar
Ideally your shock should be centered in it's travel at ride height. if the weight of the car is on the wheels and you can't extend the shock far enough to get it installed the shock is too short. I'm not sure how you would measure suspension travel on the ear to determine what the proper length would be.
Jeff
yellow69RS is offline
post #4 of 10 (permalink) Old Feb 3rd, 20, 07:50 AM
An alternative to the stock front mount shocks is DSE's inboard shock mounting kit that moves staggered shocks inside the springs for added tire clearance and has it's own upper mounting point on a weld in frame cross-member. This way you gain room for a bigger tire and control over your rear end.
Big Dave
57vette likes this.
Larger Dave is online now
post #5 of 10 (permalink) Old Feb 3rd, 20, 09:39 AM Thread Starter
Brett....
The shock hits the axle when trying to route to the rear mounting point. It's not a length issue it's an angle issue. I thought maybe my axle was too far aft but it is lined up with the bolt on the leaf springs so I am doubting that is the case.
Dumb question that I should know - Can a '67 with shocks in front of the axle simply have the mounting plates changed and have one shock go behind the axle or is it a much more involved change?
Thanks!
AZ_Bill is offline
post #6 of 10 (permalink) Old Feb 3rd, 20, 05:32 PM
Thanks!
The upper shock mounts would have to be relocated. It would take a lot of work to do.
Look up a 67 trunk pan and a 68 trunk pan to see the differences.
dhutton likes this.
my 67' build thread:
allanjs is offline
post #7 of 10 (permalink) Old Feb 3rd, 20, 06:48 PM
Darin
ilikeike's Avatar
https://www.performanceonline.com/19...SABEgKzS_D_BwE
1968 Butternut Coupe,
421" Dart SHP block
TKO 600 RR
Dutchman 9" w/3.70
Global West arms
Budnik wheels
ilikeike is offline
post #8 of 10 (permalink) Old Feb 4th, 20, 10:13 AM Thread Starter
That's a pretty interesting kit - definitely an option
AZ_Bill is offline
post #9 of 10 (permalink) Old Feb 4th, 20, 10:57 AM
Vega$69's Avatar
I would think going from staggered to non staggered would be a step backwards and cause wheel hop?
Vega$69 is offline
post #10 of 10 (permalink) Old Feb 5th, 20, 08:44 AM Thread Starter
Staggered is not an option for me at the moment unless I went with a solution that relocates the upper shock mounts. The only way I will make a change right now would be if there were a kit to go to staggered but I will probably stay with the stock configuration and if I have issues I will go to a 4-link setup.
AZ_Bill is offline
