Want to put power steering in my 68 Camaro? - Team Camaro Tech
 6Likes
  • 2 Post By Just 1 More
  • 4 Post By rgwiz
post #1 of 12 (permalink) Old Feb 14th, 20, 06:27 PM Thread Starter
Probationer
I currently have a 68 Camaro And I want to put power steering And it. Any advice on what power steering gearbox I should use. ?
Haro308 is offline
post #2 of 12 (permalink) Old Feb 14th, 20, 08:27 PM
Michael
Re: Want to put power steering in my 68 Camaro?
Call Summit Racing they have many.Low end boxes to very high end.I bought everything for my 69.Good luck
1969
mpeters is offline
post #3 of 12 (permalink) Old Feb 15th, 20, 09:07 AM
Frank
I picked everything up from Summit for my 68.
Used the AGR box 492117 12:1 $431
PSC pump SG254B 12.7:1 $475
Moroso remote reservoir
and made my own lines with fitting and hose from https://hotrodfuelhose.com/
Resized_20190714_123032 by F G, on Flickr
Resized_20190714_170642 by F G, on Flickr
Resized_20190714_170634 by F G, on Flickr
Resized_20190714_170625 by F G, on Flickr
ME4NSTRK69 and frog7151 like this.
'68 Camaro 454, 4sp
Just 1 More is offline
post #4 of 12 (permalink) Old Feb 15th, 20, 12:05 PM
No need to spend big $$ if you're not autocrossing etc. You can buy a Jeep Grand Cherokee
box from Rockauto for reasonable $$. Read this thread first.
https://www.camaros.net/forums/16-br...ering-box.html
my 67' build thread:
allanjs is offline
post #5 of 12 (permalink) Old Feb 15th, 20, 12:14 PM
ME4NSTRK69's Avatar
I went with this box and so far im very happy with it.
https://www.ss396.com/mm5/merchant.m...parttopsellers
1969 Camaro 350 200r4 342 Posi
1987 WE4 Turbo Regal E85
2003 Sierra Stepside RCSB Belltech dropped
MY BUILD THREAD:
ME4NSTRK69 is offline
post #6 of 12 (permalink) Old Feb 16th, 20, 07:43 AM
Ray
I admire the top end work like Frank's. But, as also mentioned, adding PS can be accomplished many different ways.
I did mine with the help of a fellow member that was selling a 3 turn '67 quick gear box with the original tank. I got the correct pulleys and brackets for my '68 350 off eBay and finished up with new hoses, fan belt and rag joint from the catalogs.
I may have spent under $200, but that's with using all stock components.
'68 rs/SS 350 M-21 posi
numbers matching
rgwiz is offline
post #7 of 12 (permalink) Old Feb 19th, 20, 11:48 PM
Bob
I bought a re-manufactured box from Cardone for around $100. I destroyed my original trying to replace the seals. I think I got the pump from Rockauto. Pullys and brackets from March. Not too expensive and looks good.
bobgonefishin is offline
post #8 of 12 (permalink) Old Feb 20th, 20, 09:22 AM
shawn
Frank, do you have any heat issues with the power steering box being so close to the headers? Mine is very close as well.
frog7151 is offline
post #9 of 12 (permalink) Old Feb 20th, 20, 09:40 AM
Ray
It depends on the headers you use.
At shows or cruise nights you'll find nine out of ten 1st Gen's that have the mandatory hammer ding on at least one header tube.
numbers matching
rgwiz is offline
post #10 of 12 (permalink) Old Feb 20th, 20, 12:58 PM
Frank
It's close, to close, and i'm sure it makes the fluid hotter than it needs to be. I'm adding a PS cooler to hopefully help. Something like this https://www.summitracing.com/parts/sum-331018 and i'm thinking i'll mount it on the bottom front of the radiator core support.
'68 Camaro 454, 4sp
post #11 of 12 (permalink) Old Feb 20th, 20, 04:21 PM
shawn
I will probably end up going with something similar.
frog7151 is offline
post #12 of 12 (permalink) Old Feb 25th, 20, 12:49 PM
Randy Brutout
Randy Brutout's Avatar
I used a website called Performance On Line (POL). I ordered their 14:1 kit for around $600 and I'm really satisfied with the results. Good luck!
1968 Camaro Super Sport, 462ci, 7.4 ltr, Holley 600, Edelbrock Performer 2.0, Accel HEI, Muncie 4-speed, Hurst, 12-bolt posi 355s, Flow Master, Lakewood Traction Bars
Randy Brutout is offline
