10 Bolt 8.5 Inch rearend swap - Team Camaro Tech
post #1 of 8 (permalink) Old Jan 17th, 06, 02:25 PM Thread Starter
Anyone know if there is a 10 bolt 8.5 inch rearend that will directly bolt onto a 68. If so what car it comes from thanks
lowrider_33 is offline
post #2 of 8 (permalink) Old Jan 17th, 06, 04:33 PM
armin
Send a message via MSN to pro1
Re: 10 Bolt 8.5 Inch rearend swap
71-77 nova.omega,skylark etc.
pro1 is offline
post #3 of 8 (permalink) Old Jan 17th, 06, 06:17 PM
low rider,
I actually just had this same discussion in the below thread.
Hope it helps
https://www.camaros.net/forums/showthread.php?t=71327
I purchased a '73 Nova 10 bolt 8.5, but I have not installed it yet as I am going to rebuild it.
Gregs68U-U is offline
post #4 of 8 (permalink) Old Jan 17th, 06, 06:20 PM
Keith
Nova, Omega,Ventura, Apollo rearends. Some 71's used the 8.5 some the 8.2, you'll have to check. All 72-75 used the 8.5. All 76-79 with factory V-8 used teh 8.5, the 6cyl. in 76-79's used a 7.5. All will bolt in.
69X11 is offline
post #5 of 8 (permalink) Old Jan 19th, 06, 08:07 AM
I would have thought it was Nova (and such) 71 - 74?? I thought they got a wider rear in 75 when the body style changed... no?? Don't quote me on that, but that's what I thunk I heard.
I have a 8.5 from a 73 Nova in my 68. It was a direct bolt-in.
Robb
robbm is offline
post #6 of 8 (permalink) Old Jan 19th, 06, 08:19 AM
Gene
A quote from 69X11 on another thread:
"The only thing I don't understand is the whole the 2nd gen rear won't fit a first gen car thing. Yes you have to move the spring perches and shorten the drive shaft, but that's it. I have sitting side by side on my garage floor the original 8.2P out of my 67 Firebird and a 8.5 disc brake rear end out of a 79 Trans am. Both are completely assembled minus brakes and both are the exact same width from axle flange to axle flange. I have a 8.5 out of a 74 Camaro under my 69 and the wheels fit exactally the same as they did with the stock 8.2C axle.So my question is, which cars exactally had a wider rear end, becase it's very clear to me that it's not all the second gen cars."
1969 Camaro - Intense Blue Pearlcoat/white (Baldwin-Motion paint scheme), stock 6.2 liter L92 with VVT, LS3 intake, Doug's Headers; Tremec TKO, 3.73 12-bolt posi.
gheatly is offline
post #7 of 8 (permalink) Old Jan 19th, 06, 04:42 PM
there is an article in the Feb Chevy Hi Performance or Car Craft that details this swap exactly
phoenixdawg is offline
post #8 of 8 (permalink) Old Jan 19th, 06, 08:50 PM
2.gen camaro rear is exactly 1" long. spring perches difrent. I know because I have 2. gen and nova rear in my garage also.
67ptcamaro is offline
