2" drop spindle - Team Camaro Tech
post #1 of 9 (permalink) Old Jan 21st, 06, 05:39 PM Thread Starter
2" drop spindle
I installed 2" drop spindles with stock springs, everything is new. does anyone know if this will allow the car to drop down 2" or will it remain the same. Please help thanks...J
electric camaro is offline
post #2 of 9 (permalink) Old Jan 21st, 06, 08:55 PM
David Pozzi
davidpozzi's Avatar
Re: 2" drop spindle
It will drop 2", but check your tie rod end to tire clearance, the tie rod end drops 2 inches and usually causes trouble.
davidpozzi is offline
post #3 of 9 (permalink) Old Jan 22nd, 06, 02:59 PM
Re: 2" drop spindle
i dont really understand this question
the spindles you installed are 2" drop spindles, so as the name implies they make the car 2" lower, using the same springs
and you should check the website in david pozzi's signature, it details a lot of info about drop spindes and everything suspension, really a great site
400bird is offline
post #4 of 9 (permalink) Old Jan 22nd, 06, 03:20 PM Thread Starter
Re: 2" drop spindle
Thanks for the reply guys, I guess I have to wait and see after everything is installed. I am installing a unisteer manual rack and pinion too I hope all will work good togeather thanks again...J
post #5 of 9 (permalink) Old Jan 23rd, 06, 09:52 AM
Re: 2" drop spindle
electric camaro ...
I also have 2 inch drop spindle and stock springs. It pushed the tie rod ends WAY into the tires ( look at the Pozzi site, there is a perfect picture of what happens ) and has destroyed the tires after only 500 miles. Car also bottomed out A LOT and tires would rub the inner fenders over dips in road. I went too big on front tire size however ( 245/50-16 )
I plan on taking the spindles out and reworking everything.
Chris-in-Cali is offline
post #6 of 9 (permalink) Old Jan 23rd, 06, 07:49 PM Thread Starter
Re: 2" drop spindle
Chris in Cali- Thanks for the info...Jay
post #7 of 9 (permalink) Old Jan 23rd, 06, 08:04 PM Thread Starter
Re: 2" drop spindle
Hey Chris where did you get your drop spindles?, I got mine from CPP I put my tire on one side and it looks like I have aprox 11/4" from the rim. The tire size is 255 60 15 I hope it stays this way I dont know for sure because the frame is on stands right now, doing a total resto!!!
post #8 of 9 (permalink) Old Jan 23rd, 06, 10:15 PM
Re: 2" drop spindle
I'm not sure where my drop spindles came from. I had a locally know mechanic/restorer helping me with the total build. Which really pi$$'s me off knowing full well a professional mechanic let me car roll out of there knowing what would happen. But what's done is done. But if you've seen the specific picture on Dave Pozzi's site on drop spindles, that is exactly what mine looks like, and the inside sidewalls of both tires look like they were carved out with an ice cream scoop. Been sitting in the garage for 6 months now and I won't drive it till I can get everything fixed.
ANYWAYS :-)
Hope this little bit of info helps in whatever you doing
post #9 of 9 (permalink) Old Jan 24th, 06, 07:42 PM Thread Starter
Re: 2" drop spindle
thanks Chris.Jason
