68 Drum spindle, 15"wheel,which disc...? - Team Camaro Tech
post #1 of 5 (permalink) Old Feb 13th, 06, 09:11 PM Thread Starter
Question 68 Drum spindle, 15"wheel,which disc...?
This 68 Camaro has to stop better...I want to retain the stock drum spindle and put on a front disc setup....I have seen a few websites and they all refer to c4 or c5 setups that would require 17"or larger wheels. I have heard of using 70s corvette rotors but Im not sure about the caliper brackets? I need something simple..This is a street/strip car..but I dont want some high dollar brake label..the factory stuff would be great...any ideas..Thanks...
ez12xlr8 is offline
post #2 of 5 (permalink) Old Feb 14th, 06, 01:42 AM
Re: 68 Drum spindle, 15"wheel,which disc...?
If you want to keep a 15" wheel why don't you go with a factory disc set-up. Is there a reason why you want to keep the drum spindle? There are numerous factory equivelent smaller disc set-ups designed to fit behind the 15 inch wheels.
q2quest is offline
post #3 of 5 (permalink) Old Feb 14th, 06, 02:28 AM
Bruno
Thumbs up Re: 68 Drum spindle, 15"wheel,which disc...?
First, Welcome to Camaros.net. There's a great web page, made by our own suspension Guru and moderator, David Pozzi. Check it out and you'll find lots of answers to your concerns. http://www.pozziracing.com/
"Our affair with Camaros is a life sentence without the possibility of parole".
ORENCH is offline
post #4 of 5 (permalink) Old Feb 14th, 06, 10:56 AM Thread Starter
Did Not! Want to pull the spindles. Im over that now..Finding a stock disc donor car...Thanks for the input..
ez12xlr8 is offline
post #5 of 5 (permalink) Old Feb 14th, 06, 12:55 PM
You can use your stock drum spindles... read David Pozzi's site.
68 Camaro~LSx ~all motor
