Steering Gearbox stud - Team Camaro Tech
post #1 of 4 (permalink) Old Jun 28th, 06, 06:42 PM Thread Starter
Michael
the stud whic i belive accepts an 1 and a quater washer on my steering gearbox is stripped and the nut wont go on? well the threads are just a little messed up. and suggestions?
Radcannon is offline
post #2 of 4 (permalink) Old Jun 28th, 06, 07:01 PM
Re: Steering Gearbox stud
Are you talking about the pitman arm retaining nut that takes a very large socket to remove? Sector shaft nut? There are some thread chasers for this , unless like you say, its stripped all the way,,, its gone. Buy a new rebuilt unit. not expensive.
TC # 349
zdld17 is offline
post #3 of 4 (permalink) Old Jun 28th, 06, 10:45 PM
David Pozzi
davidpozzi's Avatar
A good opportunity to upgrade your steering box if you haven't allready done it.
davidpozzi is offline
post #4 of 4 (permalink) Old Jun 28th, 06, 10:54 PM Thread Starter
Michael
I am actually desperately in need of all my money to refinish the entire front-end on a performance budget. i took it apart three days ago finished getting everything off including ripping my breaklines on accident and need it all back on done in 3 weeks.
Replacement Part Numbers for Steering/Suspension - LONG HwyStarJoe Brakes, Suspension & Steering 14 Sep 16th, 12 11:50 AM
Steering Column reassembly Steptoe Camaro Tech 17 Jan 23rd, 07 09:48 PM
steering column binding Seakane Brakes, Suspension & Steering 16 Jun 6th, 04 04:06 PM
Front end kit in Canada Mark Yetman Brakes, Suspension & Steering 19 Mar 14th, 04 02:27 PM
Suspension Parts List davidpozzi Brakes, Suspension & Steering 3 Feb 23rd, 04 02:54 AM
