lighter motor - want stock ride height - Team Camaro Tech
post #1 of 3 (permalink) Old Jun 28th, 06, 09:24 PM Thread Starter
I am going to be putting in an LS1 (aluminum block and heads) in my 69 x11. Compared to the 350 SBC (iron heads and block), the ls1 is about 100 lbs lighter. I want a stock ride height and will be running 15" rally wheels (no pro touring setup). I would like decent handling (better than stock), but will not be doing any road racing/auto-xing. I am thinking about the 6308 moog springs, being that they would make a SBC equipped car about 1-2 inches lower, so with the lighter motor i guesstimated that i would be back to somewhat stock ride height. will these springs suffice? Also thought about the 6320's and then cutting the spring to the ride height that i want.
ross
thedong is offline
post #2 of 3 (permalink) Old Jun 28th, 06, 10:25 PM
Wes
Re: lighter motor - want stock ride height
This is rough, but I'd use the "spring rate" method,..for instance, take a stock height front spring with a spring rate of 300 lbs. It would take 300 lbs to compress the spring one inch. There are two springs sharing the load and since the engine weight is somewhat rear the two coil springs, the rear suspension is less burdened with the aluminum engine and the rear would ride slightly higher.
So, I think your front end height would only be reduced by 1/8 inch or so with the 100 lbs reduction in engine weight.
Straight-line-69 is offline
post #3 of 3 (permalink) Old Jun 30th, 06, 02:43 PM Thread Starter
thanks straight-line!
thedong is offline
Hotchkis ride height Farm Boy Brakes, Suspension & Steering 0 Jul 7th, 05 10:30 AM
69 Camaro Stock Ride Height rpol78 Brakes, Suspension & Steering 2 Aug 17th, 03 09:02 AM
ride height lowering question camrod67 Brakes, Suspension & Steering 2 Jul 11th, 03 04:13 AM
Aluminum bushings- Stock height or 1/2 drop? jrager Brakes, Suspension & Steering 3 Aug 3rd, 01 03:46 PM
stock front spring height? kubicki Brakes, Suspension & Steering 3 Apr 25th, 01 04:41 PM
