What Master Cylinder to use - Team Camaro Tech
post #1 of 2 (permalink) Old Jun 28th, 06, 09:54 PM Thread Starter
Send a message via AIM to ddonzella Send a message via Yahoo to ddonzella
Smile What Master Cylinder to use
I have installed a four wheel corvette disc brake system in my 69 SS. I was told that I can use a standard GM dual chamber master cylinder from a 4 wheel GM disc brake car without any proportioning valve. Is that true and if so what GM car should I get it from? C-4 corvette? Gen III Camaro?
Professional opinion requested. Thanks
ddonzella is offline
post #2 of 2 (permalink) Old Jun 29th, 06, 04:50 PM
JohnZ's Avatar
Re: What Master Cylinder to use
What year Corvette did the disc brake system come from? Pre-'75 Corvettes didn't use a proportioning valve at all - the proportioning was designed into the hydraulics from '65-'75 via smaller diameter caliper pistons in the rear.
JohnZ
CRG
JohnZ is offline
69 Manual Front Disc Brake Master Cylinder jeff5295 Brakes, Suspension & Steering 26 Nov 2nd, 06 11:33 PM
1967 Disk Brake Master Cylinder size/part#? 69RS/SS396ragtop Restoration Corner 0 Oct 22nd, 05 10:15 PM
Master Cylinder for Disc Brakes? ItDoRun Brakes, Suspension & Steering 3 Aug 22nd, 05 10:35 PM
What have I got - Master Cylinder dnult Brakes, Suspension & Steering 8 Jun 16th, 03 07:14 PM
