69 disc brakes on a 67?? - Team Camaro Tech
post #1 of 5 (permalink) Old Jun 29th, 06, 07:45 PM Thread Starter
I have a 67 with original disc brakes, however I do not have the calipers. I was told by a local shop that I can use the 69 rotors, calipers and wheel bearings and it will fit just fine. Is this correct? I would rather not go out and buy a whole kit. Any input would be useful....thank you.
crstenalvsean is offline
post #2 of 5 (permalink) Old Jun 29th, 06, 08:27 PM
Vince
Re: 69 disc brakes on a 67??
that is true, just not all original. If you don't care then go for it, it works fine. You can still get the 67 calipers as well.
3forme is online now
post #3 of 5 (permalink) Old Jun 29th, 06, 08:48 PM
Smile Re: 69 disc brakes on a 67??
I did the whole swap from a 69 to a 67, brackets, calipers, rotors, master cyl, booster, proportioning valve. It was a direct bolt on.
67 Plain Jane is offline
post #4 of 5 (permalink) Old Jun 30th, 06, 05:52 AM
Gary
67's and 68's used 4 piston calipers, while 69 used single piston calipers. If you want to go back original, seek out 4 piston calipers. If you don't, then you can use the 69 stuff. Single piston calipers and rotors are available from all the local auto parts stores.
Unreal is offline
post #5 of 5 (permalink) Old Jun 30th, 06, 10:45 AM
You'll have to get the 69 caliper brackets.
Check all tire/bumpstop clearences at hose/caliper at full steering lock left/right at full suspension compression and droop. Don't find out the hard way that a hose rips off or wears through.
67 bumpstop on frame can cause issues.
67 disc line J bend and bracket location may cause issues.
Using Chevelle calipers might help solve both issues on the 67s.
The hose inlet is on the bottom.
I have them on my 68, and they're what come with most disc kits.
If I didn't learn it from my my mentors, I learned it as a result.
ohcscott is offline
Updating 67 Power Disc Brakes Foggie Brakes, Suspension & Steering 4 Jul 25th, 06 09:59 AM
67 manual disc 4 piston brakes #s bobjs67rsss Tag Team 5 May 19th, 06 12:13 PM
67 disc brakes on a 69 Martin_Nissen Brakes, Suspension & Steering 2 Feb 8th, 06 11:31 AM
Will 74 Nova Disk brakes work on my 69 camaro? 695speed Brakes, Suspension & Steering 2 Feb 3rd, 06 11:12 AM
Installing rear disc brakes? ENP Brakes, Suspension & Steering 1 Jan 27th, 06 11:31 PM
