eaton rear springs - Team Camaro Tech
post #1 of 2 (permalink) Old Jun 30th, 06, 09:21 PM Thread Starter
Dan
eaton rear springs
I'm getting ready to replace my rear springs on my 69 coupe.I have a 10bolt rear end with mono leaf springs.I want to replace the rear springs with a multi 4 leaf spring.(I will need to have the mono to multi conversion) I am going to use a 15x8-15 with 4.5 bs corvette rallye wheel,and a 275/60-15 tire.
Now I called Eaton spring and they are very helpful,But they want to know if I want the spring @ stock height or +- spring height.I have no Idea what to tell them.I don't know if a 275x15-60 tire will fit at stock height or will it need to be re-arched.the Eaton people said that the stock height could be adjusted 1-3 inches from stock height.I don't want the 4x4 look but I want the tires not to rub the wheel well.Has anyone used this combo of Eaton 4 leaf springs(or 5 leaf) and 275x15-60 tire,@ stock height or 1-3 adjustment?
Thanks for your thoughts,comments. Dan
pappy's69 is offline
post #2 of 2 (permalink) Old Jul 1st, 06, 06:05 AM
Craig
Re: eaton rear springs
Im getting ready to order the same springs for my 69 Firebird.. would be interested to find out the same info.
thorpe67RS is offline
67 rear springs jdbr1 Brakes, Suspension & Steering 2 Nov 19th, 05 04:05 PM
Left and right rear springs? KevinW Brakes, Suspension & Steering 11 Feb 14th, 03 05:57 AM
Landrum rear leaf springs? bretcopsey Brakes, Suspension & Steering 3 Mar 9th, 02 11:39 PM
Lowered Rear Springs Al N Brakes, Suspension & Steering 17 Apr 5th, 00 07:39 PM
