Raising rear of car? - Team Camaro Tech
post #1 of 6 (permalink) Old Jul 1st, 06, 10:14 AM Thread Starter
Arrow Raising rear of car?
Can anyone tell me what will happen if I put a 1"1/2 to 2" block between my leaf springs and my rear axle on my 68 camaro. I would like to raise the rear and I don't know if this will lower it or raise it.
Bigwill11 is offline
post #2 of 6 (permalink) Old Jul 1st, 06, 10:18 AM
Re: Raising rear of car?
a block between the leafs and the axle (assuming this is a camaro, or at least not a pickup truck) will LOWER the car.
post #3 of 6 (permalink) Old Jul 1st, 06, 05:37 PM
As said above...
If the spings are below the axel then it will lower with blocks.
Springs on top of axel will raise with a block.
To lift with springs under axel then you'll need a shackle kit.(I hate that look).
68 Camaro~LSx ~all motor
post #4 of 6 (permalink) Old Jul 2nd, 06, 04:11 AM
Or better yet, get new springs.
post #5 of 6 (permalink) Old Jul 2nd, 06, 06:07 PM
I raised the rear with air shock and longer shackles don't do that the ride was bad. get new spring .... that what I do now.
Larry
Larry B is offline
post #6 of 6 (permalink) Old Jul 2nd, 06, 07:28 PM
Thumbs up Re: Raising rear of car?
I have always ran add-on, coil-over the shock over-load helper springs AND I like them!!
Sure she bounces, but I like a stiff car!!
My old one's are now on my workbench b/c I figure my new reworked about 175 to 200 pound or so real leaf's will be fine w/o them!!
pdq67
cowl hood adjustment 68C Body Shop 16 Jan 30th, 14 08:08 AM
Unusual JL8 Car Found travlinz28 Tag Team 48 Aug 5th, 08 06:36 AM
Rear of hood too high. Brackneyc Body Shop 10 Apr 28th, 06 07:20 PM
Door Hinge & Remount Question Dwight's Z/28 Body Shop 3 Oct 9th, 03 03:26 PM
