DSE subframe connectors - Team Camaro Tech
post #1 of 10 (permalink) Old Jul 1st, 06, 06:34 PM Thread Starter
I am considering installing DSE subframe connectors on my '69 Camaro. DSE stated that some of the floor will have to be cut to install.
Has anyone installed these? If so, how far do they protrude above the origional floor? Once carpet is installed, are they really noticable?
DSE also strongly recommended their aluminum bosy to frame bushings. How much road noise and vibration will these transmit into the car?
Thanks,
302Z/28 is offline
post #2 of 10 (permalink) Old Jul 1st, 06, 06:44 PM
Tim
Re: DSE subframe connectors
They don't stick up more than about an 1-1 1/2 inches. The factory carpet covers them very easily and they aren't noticable at all. No one would notice them without looking under the car. I don't have any experience with the bushings. I'm sure someone else can help out with those.
Once you give in you can never go back.
Currently searching for the perfect Camaro.
ungo4 is offline
post #3 of 10 (permalink) Old Jul 1st, 06, 06:52 PM
THE FRAME CONNECTORS ARE THE BEST ON THE MARKET!!! easy install and not very noticable at all.i've installed a few sets and they fit like a glove.Solid bushings have been around for decades.just a solid hockey puck.no need on a street car,then again either are the frame connectors!!!
NJTURBO is offline
post #4 of 10 (permalink) Old Jul 1st, 06, 06:52 PM
Jody
camcojb's Avatar
They are not seen once carpet is in, looks like a regular floor. The bushings work well, no problems on mine.
Jody
camcojb is offline
post #5 of 10 (permalink) Old Jul 2nd, 06, 09:06 AM
I recently installed them in my car. This should give you an idea how much they are above the floor pan:
69ProTouring is offline
post #6 of 10 (permalink) Old Jul 2nd, 06, 02:44 PM
Both are needed on most unibody vehicles. When you stiffen up the body, the suspension can do its job without any changes due to flexing. If you decide on the DSE connectors, you must run the solid bushings on the frame.
Solid frame bushings don't transfer much to the seat of the pants, as it prevents the frame from moving independent of the body, resulting in a better, more predictable ride and handling.
Tyler
Teetoe_Jones is offline
post #7 of 10 (permalink) Old Jul 2nd, 06, 06:36 PM
Banned
Thumbs up Re: DSE subframe connectors
Ditto Teetoe!!
I am very happy with the fitment of my cheap Jegs bolt-on S/F/C's!!
If I get all that carried away, I will weld them in along with the bolts now!!
And my S/F bushings are "hard as frozen hockey pucks" black POLY jobbers that I had to notch using a hacksaw so the S/F/C's would fit around the rear ones!! Crude but worked fine!!!!
pdq67
post #8 of 10 (permalink) Old Jan 1st, 07, 01:45 PM
He is correct, had them on my TTA and loved them
87GNX is offline
post #9 of 10 (permalink) Old Jan 1st, 07, 02:12 PM
madmax87's Avatar
Sent you a I.M.
madmax87 is offline
post #10 of 10 (permalink) Old Jan 1st, 07, 02:29 PM
I did 'em (connectors and mounts) and I like. Can't say if they harshened the ride, since I did coilovers, rears springs, poly bushings, and short sidewall tires all at the same time. The ride did stiffen (harshen) up, but the handling is FANTASTIC.
I plagarized an idea from 69ProTouring (Thanks Scott!) to make the subframe removable. Instead of welding it to the front subframe, I welded the SFCs to the body and bolted them to the subframe. Some may say that bolting them in defeats the purpose of welding, but, although I'm not an engineer, I can't believe there is any significant difference in rigidity with this method in the post I made below:
https://www.camaros.net/forums/showthread.php?t=86236
Making fun of my welding skilz is not allowed...
His and Hers Marina blue 67's
67FamilyFun is offline
why is it so expensive to restore?? RUSTY69 Bench Racing 54 May 1st, 07 11:04 AM
DSE subframe connectors, has anybody used them? 1968camarossrs-350 Body Shop 12 Jul 2nd, 06 12:58 PM
Thought someone might find it usefel, others dishearting!! Parts list of my project! boilermaker Camaro Tech 20 Apr 7th, 06 09:14 AM
global west subframe connectors 67ragtp Body Shop 7 Mar 9th, 06 06:18 AM
Hotchkis lowered with comp subframe connectors dank67ssrs Brakes, Suspension & Steering 4 Aug 23rd, 05 08:27 PM
